Question about Garden
Lawn tractor engine replacement
I am replacing a 14.5 HP Briggs & Stratton engine with a 17 HP on a Snapper Z- Rider Yard Cruiser. I cannot get the pulley from the main shaft which is all that remains to remove the engine. I have tried using a 3 point wheel puller only to damage the pulley. even after bracing the pull points I got the same results. What am I doing wrong?
  • Anonymous Mar 22, 2014
    with keystock
  • 16 Answers
Some pulley have grub screws on side as well as main bolt on bottom .sometimes heat is needed on pulley to make it expand
Posted on Nov 11, 2008
Take a wet shop towel,, and put it around the shaft,, at point where it comes out of motor,, so seal will not heat up and get runed,, put puller back on weel,, take oxi ace,, torch ,, medium heat,, and heat one side of weel,, and put tension,, on puller,, heat,, tension,, heat,, tension,, until weel moves,, make sure,, allen is loose,, weel should come off !!! little prayer,, won,t hurt,, !! common problem,, !! you are heating the aeria which is on the shaft,, keep shop towel wet,, so crank seal will not de grade,, good luck ,,, ****,,
Posted on Dec 04, 2008
Why doesn't throttle control work on snapper rider mower with briggs and stratton engine
I need a little more information. Does it run at an idle or is it runing at a moderate to high speed? Does the throttle lever move or is it frozen?
Jun 24, 2014 | Briggs & Stratton Garden
My Snapper 48" zero turn is running batteries dead. I just replaced the battery cut my yard once and the battery is dead. What are some possibilities?
The charging circuit is faulty and is not charging the battery when the engine is running. Best case is a bad connection or frayed cable, worst case is a faulty alternator.
Oct 29, 2013 | Briggs & Stratton Snapper 5900748 355Z...
I need to find free diagram for linkage hookup on a 10 HP Briggs & Stratton Snapper riding lawnmower
I would go to mytractorforum.com, click on the word 'forum' just to the right of the tractor wheel, and scroll down to the small engines and repair section. Inside 'stickies' is a directory of B&S service manuals.
Apr 14, 2013 | Snapper Garden
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Snapper yard cruiser 33in. cut joystick blows
Unplug the engagement clutch[it bolts to the motors crank] and try to engage again.If the fuse does'nt blow you need a clutch.If it does still blow you need a switch or you have a short in the harness.
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
386 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
