Toshiba 50H82 50 in. Rear Projection Television
Problem for Toshiba 50H82 50 in. Rear Projection Television
Flickering Lines
By racin on Sep 24, 2006
I have an intermittent problem with thin flickering blue lines along the top third of the screen and thin pink flickering lines along the bottom third of the screen. The center third looks ok. Usually they come and go recently they have become more apparent and almost continuous. When the set was new it would do this once in a while. It's about 4 years old now. Thanks for the help.
Comments:
Sep 27, 2006
- Thanks Walter,
Can you five me a ballpark figure on what that cost should be? I'm in western NY.
Thanks again!
Best Solution
posted on Sep 27, 2006
Helpful)
bunkermaster
Rank: Master
Rating: 89%, 22 votes
I recommend you call a shop and ask them how much it will be to replace the Convergence amps STK-392-110(2are in the set) 99%shure thats your Problem
Good Luck Walter Grzybowski
Was this helpful?
Yes
No
Popular Solutions for Toshiba 50H82 50 in. Rear
Questions and Unsolved Problems for Toshiba 50H82 50 in. Rear
Do you recommend Toshiba 50H82 50 in. Rear Projection Television?
Answer
Answer
How do I know I need a new projection lamp? My Toshiba TV is showing blue images around all the... (More)
Answer
screen size options will not fix the problem of improper fit - ie. scores running on the bottom of... (More)
Answer
when i plug the tv in the power light just blinks. never saw any signs of color tubes going out. do... (More)
Answer
toshiba projection tv model TP50F61 power light blinks but picture nor sound will come on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection Televisions Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
