Question about Microsoft Xbox 360 Console
3 red lights
3 red lights top right hand one unlit as u look at the box
    Scholar:
  • 45 Answers
When someone say that his/her Xbox is having 3 red lights problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the Problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Posted on Feb 21, 2009
  • 488 Answers
Oh no!its the RROD..red ring of death..u will need a replacement console..do call microsoft for a new one..i got three such!hope u get urs soon!!
Posted on Nov 02, 2008
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
Tip
Fuse list ford contour
Engine bay fuse box
3 60 Yellow ABS
22 7.5 Brown ABS
32 7.5 Brown Radio
38 Unused
Engine bay fuse box
R3 Blue AC cut-out
R4 Brown AC clutch
R6 Yellow Starter
R7 Brown Horns
R8 Brown Fuel pump
R16 Black Ignition
R17 Unused
R20 Unused
R21 Unused
R26 Unused
Glove box
Step/Courtesy light
Trunk/Cargo area
Instrument-general
on Apr 15, 2015 | Ford Contour Cars & Trucks
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
I have a 274V outlet w/ switch for my garbage disposal. I hooked it up and used a MICRONTA 3-prong circuit tester on the power outlet to make sure it was wired correctly and it showed that the right LED...
you are missing something
you describe 3 led lights --2 green and one unlit then you go on about a red led light
suggest that you get in an accredited electrician to check the circuit
it is possible that you are testing with the wring tester
Mar 27, 2017 | Cooper Wiring Devices 274V-BOX DECORATOR...
Xbox 360. RED RINGS (top right section only one unlit). Orange light on powerpack. Is powerpack the problem?
Yes, to a certain extent. You need to disconnect the cable from the wall and system, let it cool, and do what you can to get any dust or debris out of the vents on the brick. Reconnect everything and if you still have 3 red rings, you need to contact Microsoft for a repair, as you have a system failure.
Nov 04, 2010 | Microsoft Xbox 360 Console
3 red lights on
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support
(source: www.microsoft.com)Kind Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Tree lights in red
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
My console plays my games, but there is a full red ring? what does this mean?
OUCH! You have the red ring of death! Did you by chance have xbox on it's side for a long period of time instead of flat? If so, that's why. They say there made to do this, just like the old ps2's, It a load of ****. The laser lens circuit will need to be replaced. If you didn't have it on it's side, then you have a bad graphics chip, or cold solder joints, or the motherboard is shot.
Step 1: Turn on the console, and check the light on your power supply loadTOCNode(2, 'moreinformation'); The power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair request loadTOCNode(3, 'moreinformation'); Your console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: uparrow.gifBack to the top Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it on loadTOCNode(3, 'moreinformation'); This will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supply loadTOCNode(3, 'moreinformation'); If the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply.
Jan 30, 2010 | Microsoft Xbox 360 Console
SD Tech you answered my panasonic tv with 3
OK, here is what I suggest you do----remove the light box from the set and unsolder all pins on both convergence chips----see if the set will turn on and light up---you can turn the set on with the remote--its receiver is at the top of the three black lens.
sd tech
Oct 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Microsoft Xbox 360 Console Logo
21 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
