Moultrie DGS-200 Game Camera with the error code 003400, it will not allow the camera to take and pictures.Moultrie DGS-200 Game Camera with the error code 003400, it will not allow the camera to take and pictures.
AnonymousJan 21, 2009
game camera will not take pictures.do a diagnostic test comes up e-c 003400
Updating your answer with error code will be helpful. Get
your ride check for error code at any auto part shop if not done yet. The
question you asked does not mean anything if you do not mention the error code
in the question.
The engine light is telling you that the CPU has found sensor/s outside set parameters during the checking process. Have the fault codes read to determine which sensor is intermittent in operation.
Get your ride checked for error codes, as error codes will
be more helpful in solving the problem. Generally when the car stalls out, the
problem may rise due to:
1.
Faulty
fuel spark plugs
2.
Faulty ignition coil
3.
Faulty distributor
4.
Clogged
or damaged Air filter
5.
And many more
So, it is advised to get the ride checked for error code and
then update your answer.
Unless check engine light does not come up, there is no need
to worry about O2 sensor. To check O2 sensor check your ride for error codes.
The error code will tell you which sensor is faulty (If error code says faulty
O2 sensor).
Take your scooter to the Harley shop and have it checked out, I forget the sequence but that is an error code, if you feel unsafe riding because of the error code take it on a trailer. Riding to the shop with an error code or any kind of a malfunction isn't worth risking your life to be cool as a friend of mine was when he got error codes.
when you do a diagnostic test it occurs.
3400 error code
