Question about JVC GR-D20EK Camcorder
Not recognised When I connect the camcorder (JVC-D20EK) to the PC by USB lead, the following message appears on the Desktop - USB NOT RECOGNISED. In Device Manager using the Driver tab, results in 'Unknown Device'. Clicking on this takes me to the Driver details tab. Driver Details tell me that "No drivers files are required or loaded for this device." Why not? What's going on? Sources tell me I may require a software disk which will contain the necessary drivers for the PC to see the Camcorder. Is this a fact? I have searched the JVC forums and elsewhere and find that everybody is floundering around looking for the same solution. The manufacturers are of NO help at all! The posted answers are completely useless! I am using Windows XP and a computer with enough spec to alter the orbit of a small planet. Can you assist me in this bemusing and seemingly insolvable problem - at least it is to a Silver Surfer? D F Richards
  • moose76 Nov 02, 2008
    The answer I have received has not helped so far!
    Have you any information as to the software disk
    I mentioned. Is such a disk necessary?
    D F Richards
  • 1,879 Answers
It is true that sometimes a hardware cannot be recognized by Windows and a manufacturer provided driver is required.
No driver can be found for your product, here's the XP compatibility list from JVC
Posted on Nov 02, 2008
    Genius:
  • 3,422 Answers
Try connecting your camcorder to another USB port. Using one port all the time to connect and disconnect USB items a port can develop a range of files associated with configuring the USB connection. Some of these files might actually have been from your camcorder connected before, or some of these configurations could be from other USB items you connect to this port. Changing ports can often lead to an immediate good connection simply because there are no conflicting configuration files. If this does not solve your problem, we can now entertain the next process to try.
THIS IS A BIG ONE. This is the last thing to do. Before you try this process, please complete a full back up of your system. This is important as the next step can have side effects you did not entirely expect. AND Second, you might need your XP Install Disk (not in all cases). What this process is about is renewing all hardware/software configurations relating to USB connections.
Here is what you do:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB camcorder
If these suggestions are implemented and you are still have connection difficulties with your computer, there are several other things to try. If you have another XP Computer you should try connecting your player to another computer to see if the problem is a player problem or not. If it still has this problem with the next computer, it maybe be a fault of the player.
IF YOU HAVE COMPLETED ALL the above mentioned and still have a problem, you should next contact the seller of this machine for further instructions of what to do next.
  • JVC Master
  • 19,396 Answers
Try first unplugging computer power cord for five minutes, sometimes this solves the problem.
  • Ginko
    Ginko Nov 02, 2008
    The JVC-D20EK should be recognised automatically as an external disk, this will manage data on memory card only.
    If the Camcorder is not recognised, try unplugging power cord for ten minutes, or if it is a laptop unplug power and remove battery at same time.
    To transfer tapes you need to download generic JVC software.
    Here is the software download page for US/Canada.
  • Ginko
    Ginko Nov 02, 2008
    Check the user manual here go to page 33.
    It says USB is enabled nad software is available only for JVC D50/D40 only.
    No software had even been distibuted for D20, D20 does not connect through USB.
    For your model you need to use a PC with DV connector, not USB.
    The n use the PC video card software to capture files.
    That is the reason why nobody can get drivers.
JVC Everio MG57EK windows 7 "USB device not recognised"
w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply Hope it helps.
Dec 28, 2012 | JVC Gz-mg57ek Hard Disk Camcorder /...
HAVE A JVC GRD370 AS ITS USB NOT CONNECT TO PC HOW IT IS CONNECTED
You have to adapters, I also had this camera. It might be cheaper to get a later model.
Mar 04, 2011 | JVC GR-D20EK Camcorder
Hi i have an everio gz-mg 135 and when i connect it to my pc to back up files the message "usb device not recognised. One of the usb devices attached has malfunctioned. Windows does not recognise...
- Make sure you have been installed JVC driver on your PC - If your PC has multi ports USB, just try other ports to make connection - check your firewire, it may be malfunctioned . Try other USB cables
Jan 16, 2011 | JVC Everio GZ-MG130 Camcorder
I have a JVC GR-D250 camcorder. When I connect firewire cable (that has come with the camera) to the PC it gives message "USB device not recognised". If I check the Device Manager it shows "Unknown...
You should have a DV Cable 4-pin to 4-pin firewire (part number VC-VDV204U ) which came with your camera. It would not have firewire on one end and usb on the other. They are two seperate technologies. see http://www.wisegeek.com/what-is-a-firewire-to-usb-adapter.htm
May 02, 2009 | JVC GR-D250 Mini DV Digital Camcorder
USB cable to connect JVC camcorder to PC
Hi there, found the following cable on ebay - the picture clearly shows both ends so you can verify that it will plug into your camcorder.
http://cgi.ebay.com/For-JVC-Camcorder-Mini-DV-to-PC-Computer-USB-Lead-Cable_W0QQitemZ350183177004QQihZ022QQcategoryZ139969QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Apr 11, 2009 | HP Computers & Internet
PC does not recognise Camcorder when connect via USB Cable
my pc does not recognise my camcorder gr-d63 when connected
Dec 28, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Cant get it to play on tv
Look in the TV manual - without knowing the complete details we are unable to help you.
May 25, 2017 | JVC GR-D20EK Camcorder
Jvc gr-d370as - help connecting to Mac - Date and Time Setting
hi there on the front there is a small wheel turn your switch to the letter (m) then press down the small wheel on the right of machine, this will give you the menu so you cant change date from that hope that helps
mike
Jun 23, 2008 | JVC GR-D20EK Camcorder
Unknown device
Please load the Software cd which is providing with camera.If don't have try to download from the jvc internet site and install in your pc then check
Dec 18, 2007 | JVC GR-D20EK Camcorder
USB connection is not recognised by computer
Where can I download the Panasonic video camera model no. VDR-D300 from the Internet?
Nov 14, 2007 | Panasonic VDR-D300 DVD Camcorder
JVC GR-D20EK Camcorder Logo
27 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
