Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Rescue mode v1.13
Errmmm i turnt my mp3 on and it came up with this option screen: Rescue Mode v1.13 Boot v1.2 HW V0.0.1 1. clean up 2.format all 3.reload OS 4. reboot uumm, i dnt know wot to do, i have all my songs on der and there is no way i can get them off.. rebboting hasnt solved the problem, can anyone give me any advice... i have a Nomad jukebox Zen Xtra 30 GB
  • 17 more comments
  • Anonymous Nov 09, 2007
    Tried everything . . . . nothing works . . . .
  • pusram68 Dec 02, 2007
    when trying to connect my Zen Xtra to my pc via usb, does not recognize the mp3 player. what could be the cause
  • Anonymous Dec 25, 2007
    same problem
  • DerekHamlet Feb 01, 2008
    I had the same problem. I searched the web endlessly, tried a million things, contacted Creative (what a disappointment), tried the tap tap technique and got more and more depressed.
    I did get it fixed.
    Firstly, the tap tap method can only be jiggling something that is not making a good connection, or a stuck drive or something like that.
    Getting rid of all things creative, ensuring wmp 10 is loaded and media runtime 11 is not there is important. I tried to do that with no success.
    Finally I dragged out an old laptop, wiped its operating system, loaded xp pro, upgraded to wmp 10, loaded the driver, firmware and latest version of creatives software onto the desktop.
    Then I did the following:
    I too upgraded my firmware and landed up with just the rescue screen
    Here is what I did
    A) Go to control Panel->add remove programs->Remove all Creative applications and drivers you
    B) Reboot your PC
    C) Download the latest Drivers (Not Firmware) and Install them
    d)Reboot and Ensure Your device manager shows Windows Portable Device and does contain Zen Xtra
    e)Download and Install ZENZ_PCAPP_LB_1_40_03_MTP.exe
    f) While Installing - The program will complain that It still cannot see your zen..Keep Clicking OK to retry
    g)After the 3rd (OK Clicks) attempt - It proceeds to install the balance of the software
    h)Reboot your PC - after the reboot you should notice that ur ZEN shows the USB SYNC is ok- it shows the circular arrow
    I) Run the Firmware Upgrade ZenXtraP4SAudible_PCFW_LB_2_10_03.exe
    It worked.
    The only thing that seemed different than the above was that when the firmware started to load it said it was rebuilding the library. That process seemed to get close to the end, but just did not complete.
    After an hour i gave up and closed it. I disconnected the player and believe it or not everything was there, it showed the correct size of drive and all of the libraries were there.
    You cannot imagine my relief to have my friend back.
    I'm not suggesting that this method or any other method is the correct one.
    I am suggesting that you be patient, search lots of different lists and don't give up. If your hard drive can be heard to spin up, it's probably okay.
    For some reason Creative's firmware is very very finicky about how it can be inveigled out of rescue mode.
    Best of luck to all of you who face the same problem.
    I so look forward to the generation of mp3 players that have 120GB flash drives.
    oh, yeah, save your pennies and buy a good sized external hard drive to back up all your music.
  • DerekHamlet Mar 20, 2008
    Some weeks ago I posted a potential solution to the "stuck in rescue mode" problem that can happen with a zen xtra. I did get mine operational gain but there is a problem. I can dump the firmware, reload it and get an operational player but....................... the firmware does not fully load. It says it does, but then gets stuck at the rebuilding library stage and never finishes.
    I went so far as getting an old laptop and wiping the system clean. Then I loaded XP and upgraded to media player 10. Then I plugged in the player.
    The computer saw it immediately and it went to connected mode. I then disconnected the player and started it in rescue mode, deleted the firmware put it in reload mode and plugged the player back in to the computer.
    Again it was recognized. I started firmware program and it started to load to the zen. But, it never completed. After 8 hours I disconnected the player, turned it back on. It will play music, but does not show all the music in the library. It will put music into select mode, but when I go there you do not see what the music selected is.
    When I try to load the zen drievers, the computer does not recognize and connect the zen.
    Any ideas????????????
    My next attempt will be to completely wipe (sniff) and reformat the hard drive. After that I guess it's a paper weight.
    BTW and this is important. Creative no longer supports this product in anyway. Mine was only 2 years old, but they told me they no longer have any parts and do not support technical answers. In short a 2 year old machine is no longer supported by the company. Now that's upsetting.
    It may be the new world of business, but for me Creative just fell off the list of companies whose products I will buy. Period.
  • DerekHamlet Mar 22, 2008
    This will be my final comment on my mp3 player because everything is now updated and working perfectly. I cannot remember what I did to create the problem but, ended up stuck in rescue mode, only had 20 gb showing on the 60gb drive and much of library simply did not show.
    The good news was I had 90% of the music backedup on a separate hard drive.
    After two months of unsuccessful attempts at fixing it, the best I ended up with was a machine that could play some music, would not show selected music and could not connect to a computer.
    So, I had a paper weight, could pay someone else to try and fix it or......................... reformat everything. I did it.
    Then I took a laptop, formatted the hard drive and loaded xp, then upgraded windows media player to version 10.
    I loaded the firmware program onto the desktop.
    Then I plugged in the zen. It was recognized immediately as a zen and was given a drive number.
    Then I started the load firmware file. Interestingly it said this program is the same as the firmware on your device, do you want to load it anyway.
    Well, I had deleted the firmware via rescue mode, but I said proceed.
    Bingo, it loaded in abohut 30 seconds, then it said "press reset".
    It had never done that before. I did and it completed, booted and rebuilt the library. Of course there was no library to rebuild.
    Then I took it back to my desktop, connected it and again it was recognized. I took most of the day, but I reloaded 45 gb of music; it took most of the day and of course some of the files were wrong format which hung things up for a bit.
    It completed and everything works.
    Now I can go about re-loading redchair etc. and be able to edit stuff.
    I cannot stress enough that having a good sized backup drive for music and photos etc. is a desirable thing to have.
    As for creative, all I can say is grrrrrrrrrrrrrrrrrr to their customer support. They no longer support any of their devices that use hard drives and their largest flash drive player is 32 gb.
    P. S. After all the stories about people wrecking hard drives by dropping their player, I no longer put it on the desk. When loading files it sits on the floor right next to the usb slot.
    I wish y'all well with any and all of your future zen problem solutions
  • Anonymous Apr 01, 2008
    I have the same problem rescue mode V1.13
  • deuterioo Aug 06, 2008
    OS error. reload OS. Boot vl. 4, HW v0.0.1
  • Anonymous Aug 23, 2008
    the same***********
  • bmeacham Oct 01, 2008
    The tapping thing works!  I tried several times, taking the battery out to completely turn it off in between, and finally it worked.  I hit it pretty hard.  I figured, what the heck, what do I have to lose?  Now it's back.
    I had dropped it on the floor just before it quit working, so I guess that's probably not good for it.
  • sbockett Oct 06, 2008
    I had this same 'rescue mode' problem but didn't have any of the 30 gigs of music backed-up! But, the tapping solution worked the very first time I tried it ... so now I can back all this music up and start updating this thing. Not only did you all save me 300 bucks in buying a new player, but you also saved the time and effort of getting all that music back. Thanks so much!!!!!
  • xpatrob Nov 16, 2008
    I have the exact same problem, help someone?!
  • jennlmcq Dec 29, 2008
    Unfreakingbelievable! Mine stopped working this morning while I was walking to work - all I could get to come up was the rescue mode screen. When I plugged it into the computer, it looked as though there was nothing on it, when in fact, I have over 20 GBs of music on it. I thought all was lost, but fighting back the tears, I read this post and thought I'd give it a shot - it worked on the first try! Genius, simply genius! (Err, or maybe it's more along the lines of dumb luck, but either way it DID work.)
  • damitt Jan 26, 2009
    OK so I have two of them now and neither work nor does the tapping thing do it so what now SCREWED? Help!!!!!1
    OK I have two of these damn things first one got dropped started the same menu **** hadn't read this ,bought other on E-Bay started having other problems thought OK reload firmware etc now software won't see it tried tapping dang near pounding on old one what now HELP!!!
  • Anonymous Apr 24, 2009
    Hey... i was going to send my NOMAD Jukebox to Creative Labs.. its to bad that on their site they say that the Service ended for this product or something like that...
    i was trying to find another solution, because like everybody else i thought i loosed all my 30GB of music.. and my player..
    i begin to read, and i tought it was going to be something complicated, but then i actually hitted 2 or 3 times the player on the upper right corner and it went ON !!!!!
    i cant believe it...
    thanks who ever found out this..!
    Thanks a Lot !!!
  • xpatrob May 11, 2010
    I have this problem, what is the solution?
  • Chester Prudhomme
    Chester Prudhomme Mar 02, 2018
    OK, color me amazed.....this actually works! After 5 years of using my Zen as a paperweight (not having it working did get me into Zunes though) I tried this today - reset and hit it on me knee 3 or 4 times. Works like a Champ now.....Thanx!
  • Skyhyde Flow
    Skyhyde Flow Jun 09, 2018
    Oh it works .. I just sign up and join fix to say thank you tap tap tap until the turn table turns hehe
Ok , so did this person who tried this first just try it out of frustration? This is so crazy but we tried 4 times before it worked. What the heck. Does anyone have any guesses as to why it worked.
Thank you thank you - you just saved me 300.00.
Posted on Dec 02, 2007
  • Hilary Kimbel
    Hilary Kimbel Feb 24, 2014
    Maybe they just got lucky? I don't know, appliances never work for me, even when they don't need to be repaired. As simple as it sounds, my brother is a firm believer in just turning it off and on again. A lot of times, that actually does work. www.abbeyplumbingcanberra.com.au
I just tried it and it works!!!!!!!
Posted on Nov 20, 2009
Tapping it has just worked for me as well. Amazing !
Posted on Apr 23, 2009
Tapping works! incredible! don't need to fork out for another 30GB player!
Posted on Sep 27, 2008
This is dangerous because it risks deleting all your songs (I hope you have them backed up somewhere). There is a reset hole on the left side of my machine and I stuck a pin in there and reset the player. That has solved the problem for me at least temporarily. It has been less than a day since I did it.
Posted on Sep 15, 2008
Can I join in on the thank yous? I could hear the disk trying to spin up, "whir whir whir click"...
Reboot, wait until you get the EAX logo, tap HARD (against the palm of my hand did not work) and voila! dont you know my jukebox works again!
THANK YOU!
Posted on Aug 12, 2008
This actually works,if the tap doctor tapped as much *** he'd ne a legend!!
Posted on Aug 03, 2008
I followed solution #7 instructions
B) Reboot your PC
The only problem was that when firmware upgrade said player was rebooting (it was not) so I reset the Zen with a paper clip.
When it came back up the firmware install finished. I reloaded my songs and everything works great. Thanks to everyone for the great comments and info.
Posted on Jul 21, 2008
Holly S**t!!! I can't believe the tapping worked! I had to sign up for this website just so I could submit my thanks.
This is my second Zen Xtra. I ended buying a cheap used one on Ebay because my first one started having the headphone jack issue, so I just swapped the hard drive from the first into the used one (the fabled soldering fix didn't work for me). Worked great... for 8 months.
Today, I just plugged it in and the hard drive wouldn't spin up (went to recovery mode). Having dealt with Nomad firmware issues before, I was quickly anticipating the worst. A complete wiping of the hard drive and reloading firmware. Thank God I found this suggestion before I jumped off the deep end. I can't believe it worked.
Posted on Jul 10, 2008
Totally skeptical... but I just decided that I didn't have anything to lose. When it's starting up. It might got to the rescue mode screen. hit reboot. It spun up after I tried that a couple of times!
Good post bro.
Posted on Jun 11, 2008
The TAP thing Worked!!!!!!!! Unbelievable...it's probably the first time ever something like that has worked for me!!!!
Tap above the Menu button when the EAX logo comes up a few times....you'll feel the drive kick in.....seriously.
Posted on Jun 09, 2008
I was trying to my firmware when mine got stuck in recovery mode. My computer wouldnt install the driver properly and i couldnt get the firmware to upgrade...
So I did what it says in
Comment by DerekHamlet, posted on Feb 01, 2008. After trying many different things before, what Derek said he did worked for me! Thanks Derek. I also tried this on a computer other than my own, I'm not sure if that had anything to do with it. Thanks again.
Posted on May 27, 2008
Tapping it......... need say more.... just crazy. can't believe that silly tap worked.....thx
Posted on May 25, 2008
Tapping it really worked. Thank you for the advice. I almost panicked.
Posted on Apr 28, 2008
Marry me tap doctor, u are the bomb!!!!
Posted on Mar 24, 2008
Wtf thats kkrazy :) i was bout to throw it away and buy an ipod
Posted on Mar 23, 2008
What the HECK! My son's 40GB Nomad Zen Xtra has been toast for probably two years. Whenever I see it I just think of all that dough sitting there wasted. I picked it up off the desk today and because the charger just happened to be sitting next to it, charged the battery, got the "rescue mode" screen, then searched for troubleshooting and got this site. To be brief, I reset, tapped it on the desk at the recommended time and now I sit here listening to my son's crappy music. I guess no the old man has an MP3 player. Now I just have to figure out how to use it. God bless whoever posted solutions and tips to this thread.
Posted on Mar 14, 2008
As if it hasn't been said enough already. Tapping it does work. I had a guy listen to it and he said the hard drive was toast, but not after a few taps, though you do have to tap it at the right time when starting up. I don't know when it was because I had it up to my ear when I got it working. Nice Fix
Posted on Mar 13, 2008
The tapping works!!! If your's is stuck on the rescue mode screen, press the reset button. Then when the EAX logo comes up, start tapping as previously described, on the right side, above the menu button. Tap it on a desk. Presto. It works again. Thanks so much!
Posted on Mar 01, 2008
Awesome....tapping worked for me too!!! At first it didn't, but I was just tapping it against the palm of my hand, but then I tried tapping it twice against my desk and it workd!!!! Thanks everyone!!!
Posted on Feb 28, 2008
Unbelievable!!!!!!!!!!!!!!!!!! tap tap doctor thank you.....
if you are trying and it hasn't worked yet, don't let up.
took several times but worked eventually by tapping when you turn it on, just above the menu button as it spins and tries booting up
Posted on Feb 27, 2008
  • 4 Answers
For those of you who said to tap it on the right side of the EAX logo i could kiss you!!! thank you! it worked...
Posted on Feb 05, 2008
Same problem for me. Took a tumble, and was in the recovery mode saying Harddisk error. Tried tapping and it worked. Didn't lose any files or any music.
Posted on Jan 14, 2008
I ad my suspisions but this seriously works, thank ou so much i have saved 30 gb f music and photos, my whole life!!!!!!
Posted on Jan 13, 2008
Omg you are seriously a genius!!! I even had a techy check it out only to hear that i needed to buy a new one. YOU SAVED ME SO MUCH MONEY AND ALMOST 1000 songs!!! thank you thank you thank you!!
Posted on Jan 10, 2008
I tried the tap and it worked but its still not showing up when i connect it to the pc and open up nomad explorer...
Posted on Jan 02, 2008
Yeah mine did the same thing, was in the rescue mode gave it a few taps to the right hand side and IT WORKED
it then went onto rebuilding library
XD
perfect
thanks a lot
Posted on Dec 17, 2007
I too tried the "tapping" solution and it worked!
Posted on Nov 29, 2007
Absolutely BIZZARRRE!!!!! But the Tapping WORKS!! Thanks ! Vive le Internet
Posted on Nov 18, 2007
Im amazed! Its ridiculous! I tried it as a joke but it worked!!! It all of a sudden burst into life!
Posted on Nov 15, 2007
This is unbelievable!!! The tappig solutions worked for me too but only after few tries. The key is to hear a clicking sound and after that the disk starts spinning. I searched creative's support knowledgebase without much help. Thanks a lot.
Posted on Nov 12, 2007
Holly crap ut worked!! That is the stupids way to fix something. thank alot.
Posted on Nov 05, 2007
Did it too and it worked for me as well!  Thank God!
Posted on Oct 30, 2007
OK - NEVER EVER EVER would have believed it... but it WORKED!!! Thanks
Posted on Oct 19, 2007
My zen was locked into the same "boot" mode and there was nothing I could do about it.  I threw it in a drawer for over a year and pulled it out after reading about your "tapping" suggestion.
I balked and did not think it would work but figured it was worth
a try.  I 'll be darn, after the first tap I heard the hard drive start to spin and lo and behold the menu came up.  Thanks a million for your solution.
Posted on Oct 16, 2007
WOW! I'm glad I found this. I just dropped my Zen and the rescue mode kept coming up. The tapping works. You might have to tap a little hard. It took me a couple of tries to figure it out. Thanks!
Posted on Oct 13, 2007
UNBELIEVABLE! Tapping on the right side, just above the menu button worked!
Posted on Oct 08, 2007
I too upgraded my firmware and landed up with just the rescue screen Here is what I did A) Go to control Panel->add remove programs->Remove all Creative applications and drivers you B) Reboot your PC C) Download the latest Drivers (Not Firmware) and Install them d)Reboot and Ensure Your device manager shows Windows Portable Device and does contain Zen Xtra e)Download and Install ZENZ_PCAPP_LB_1_40_03_MTP.exe f) While Installing - The program will complain that It still cannot see your zen..Keep Clicking OK to retry g)After the 3rd (OK Clicks) attempt - It proceeds to install the balance of the software h)Reboot your PC - after the reboot you should notice that ur ZEN shows the USB SYNC is ok- it shows the circular arrow I) Run the Firmware Upgrade ZenXtraP4SAudible_PCFW_LB_2_10_03.exe Vola...Roger
Haha, wow tapping solved it well
Posted on Oct 04, 2007
Tapping works !!! thats unreal the internet has all the answers!
Posted on Sep 30, 2007
The tap on the side seriously works, thanks so much dog, saved me alot of money. God bless the internet!
Posted on Sep 27, 2007
Wow man you really know your stuff. thanks for the fix.
Posted on Sep 07, 2007
Same thing happened to me, same "rescue mode" etc.. After trying just about everything else, I tried the "tapping" solution thinking it couldn't hut...problem solved. How bizarre, the tapping really does work
Posted on Sep 05, 2007
I recently had the same problem and thought what the heck why not try a tap like suggested above and BAM!!! IT WORKEDDD!!!! THANX FOR THE GREEAAAT advice!
Posted on Jul 30, 2007
Tap it on the right side when the EAX logos comes up. A tpa right above the menu button should do it. It's kind of silly, but BELEIVE me, it works
Posted on Jun 29, 2007
This just happened to me, literally today - same mp3 player model. It's a bit of a pain but as far as I can tell, that's it up shit creek. I've pulled it apart and had a look about at what's inside, whenever I try to format it says 'disk error' or something similar. So, to be honest, I think that's it broken. Time to find a new model..
Posted on Jan 08, 2007
My CREATIVE ZEN Micro doesn't play any media after i accidentally dropped it. Is there hope?
1. Ensure that the player is turned off
2. Remove the battery.
3. Move and hold the Power button to the Power On position and re-insert
the battery to the Zen Micro. Hold the Power button until the rescue
mode appears.
4. After 2-3 seconds the rescue menu will be displayed.
At this point the battery can safely be replaced and maintenance options
performed.
5. Four options will be displayed on the LCD screen:
? Clean Up - (To rearrange your stored data)
? Format All - (To format and remove all data)
? Reload Firmware - (Reloads your player's operating system - Do not
choose this option unless you have downloaded a firmware update from the
Creative website)
? Reboot - (Restarts your Player)
6. Select the Clean Up and then the Reboot option.
Now, please try turning off the player.
Jun 07, 2010 | Creative Labs Zen Micro MP3 Player
The rescue mode v1.13.
I would suggest that you go to this website and do firmware update:
http://www.creative.com/products/mp3/ww
Sep 24, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Start up problem
try to log on safe mode if this not work u need to format ur laptop and install a new windows
Jul 27, 2009 | Lenovo 3000 N200 T7100 1.8G 1GB 160GB...
Mad at my nomad
It appears that my Creative Nomad Jukebox is stuck in the Rescue mode. It displays the four options suchn as. 1.Clean up 2. Format all 3. REload OS 4. Reboot
It is not recognised on the computer either.
Steve
Dec 12, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Hard disk prob
hard disk is bad.
can you format?
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs Zen Touch MP3 Player
Turns on then turns right back off after 2 seconds
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved.
if you can get into recovery mode most likely bad hard drive
Nov 05, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Having big firmware problems
7. Problem solved
Oct 10, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
9,095 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
