Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
PANAFAX UF-585 Battery is fine, monitor receives dial tone through phone line, but machine will still not send a fax.
  • 2,120 Answers
Bad fax stuck in memory. Press:
monitor key slowly 4 times
scroll down to ALL JOB CLEAR
Posted on Nov 02, 2008
Cannot receive faxes
I quick way to really determine if the line could be a problem is try dialing your fax from another phone ,like a cell phone and just listen. What do you hear, noise, a recording, or do you hear the squelch tone that your fax machines should be putting out. If not then the line could still be the problem. Also if you recently switched to a DSL line then you should get a DSL filter and install it inline on your fax line. Also does your fax ring like it's trying to pick-up? If so, do you have the reception mode incorrectly set to TAD or manual mode.
Good Luck
Mar 16, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Fax can not be send and received
press the monitor should hear a dial-tone...if not try below.
Check the phone line with a regular phone plugged into the wall jack.
Mar 11, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Panafax 585 block fax reception?
look at your settings again
Fax number 1 set to tel
Fax number 2 set to fax / tel
Feb 18, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
We can't send faxes.
call the fax number from a regular to check for fax tones.
plug in a regular phone to check for a dial-tone.
Feb 02, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Sending Documents
First the battery.
Along the top edge of the operation panel you will see a blue tab. just to the left of that tab you will see another beige tab of the same size, this is the battery holder.
Open the toner door and open the feeder ...pull upwards 1 inch until it stops.
Pull the beige tab out...not the blue one.
Take the battery to radio shack or CVS Pharmacy and match it up....CR-2032.
Next step:
press the MONITOR key and listen for a dial tone.
plug a regular phone into the phone jack to check for a dial-tone.
If all else fails.
scroll down to SHIPMENT SET
press set
wait for the machine to initialize and reboot itself.
Oct 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Sending Faxes
there is no need to change the setting.just feed the document to be sent and dial the number of the recipient.after hearing the fax tone press enter key
May 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax uf585
there might be an incomlete file waiting to be sent again in which case the last document will go into a que and be delayed. (maybe) you can retry the docoment again by pressing the memory button and sending directly, press the monitor buttonfirst and listen for dial tone, the send
Apr 17, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
196 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
