Forgot user name and password
Thank you,
I have an d-link 624 air plus xtream G wireless router. I don't remember the username and password. can u help?
Cordialy Your,
jesse ravenel
  • Anonymous Mar 21, 2014
    Can't get in my phone...I forgot lock pattern and phone doesn't accept my User name
  • 488 Answers
Please try admin as username and press enter keeping password blank..or try admin and admin..i hope it helps..
otheriwse u may have to reset the router by pressing for 10 seconds on the reset button on the back or bottom of the device..
hope it helps!
Posted on Nov 02, 2008
How can I change my D-Link wireless password?
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router) (unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose/change the Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Also, for additional security, you may try the followng steps: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback and approciate the efforts.
CreativeTECH
Apr 01, 2011 | D-Link DI-624 Air Plus XtremeG Wireless...
I forgot username and password for my D-link DI- 624 how do I reset ?
At the back of the modem is a reset button. hold that down for 3 seconds.
The Ip will now be 192.168.0.1 and username: admin
No password.
Sep 10, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
We reset the d-link di-624 wireless router and now it will not let us sign back on without the username and password which we do not remember. how do i factory reset the router?
Hi, when you reset your router the password is reset to default, and that default is admin admin. And to reset it, at the rear is a small hole in the hole is a button, remove from the power, and depress the button for a few seconds, then connect the power and try to logon again with your browser using the default settings.
It is also all explained in your user manual link below...
http://www.retrevo.com/support/D-link-DI-624-Wireless-Routers-manual/id/420ci368/t/2/
Aug 18, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Where to find my new Username and password to re-config the Route
you can reset your router, at the back you easily find very little button which indicates that is the reset button. press reset then you will be able to fix your new user name & password.
Thanks
May 20, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
How do you set up the password? Does this prevent
You may access your touter homepage by typing 192.168.0.1. username is User and leave the password blank. click home tab and click wireless tab. Set your SSID name. This the name that you want on your network and this is visible to all when they tried to search for wireless network. Enable WEP. Select WEP input key you wish to use.
May 11, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
USER NAME AND/OR PASSWORD
There is no way to obtain your username and password. Not an easy way anyways.
Your best bet is to reset the router, and reconfigure it. Good Luck.
Jun 20, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I forgot my username and password and want to create a VPN or remote connection
If you've forgotten the username and password, there is really no viable solution other than resetting the router. All the software can be found on linksys' website, along with manuals for reconfiguring your router. Breakout your trusty paperclip and press the reset button on the back of the router. Reconfiguring should only take a few minutes. The default username will be "admin" and the default password is "password" (both without the quotes.)
Manual
No software is actually required to install the router. Any information needed will be in the manaul, provided above.
Hope this helps!
May 29, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
I have reinstalled an old D-Link DI 624 system on my PC. The router apparently has an old password and network name (that I don't remember) so I cant enter the network with my new lap top (which is the...
Resetting the router would clear the username and password. The you can go to 192.168.0.1 in your browser and set a new username and password.
D-Link Router reset
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
The user manual is on this link:
http://www.scribd.com/doc/2091490/DI624-manual
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 19, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
How do I secure my D-Link Air Plus Xtreme G DI-624 wireless route
If you want to secure the router itself you have to launch your web browser. Type in the router's ip address on the address bar. Admin is the default username and leave the password field blank. Click on the Tools tab then make sure that Admin is highlighted to the top left corner of the page. Then change your administrative username and password on that page and click apply.
If you want to secure your wireless network. you have to launch your web browser. Type in the router's ip address on the address bar. Admin is the default username and leave the password field blank. Click on the Home tab then click on wireless to the right of the page. Make up something for your ssid. Select enabled for wep. Then delete the all zeros on key 1 and make up something for your password. Make sure that your password is 10 digits and you can only use numbers from 0-9 and letters from a-f. then click apply.
May 02, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Password problem
Open out a paper clip, pull the power connection out of the back of the DLink.
On the back of the DLink is a tiny hole with "reset" written above it, poke the end of the paper clip into the hole untill you feel a tiny switch click down, hold the switch down and put the power plug back in (this takes three hands) hold the switch down for ten seconds and your modem/router will be set back to factory settings.
username Admin
password Admin
try admin and try with username only or with password only.
It's been a month or two since I did a DLink and I cant remember which it is.
Jul 22, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
