Question about Canon MF8180C Color Laser MFC Printer
Canon copier ir600 problem
When i start taking copies E031 appears.i know it is the printer counter problem.i have changed counters,d,c controler board.even the wiring from dc board to counter is ok.
    Sergeant:
    Champion:
  • 246 Answers
Try to reset the machine and use it
Posted on Nov 07, 2008
Have an error code on Imagerunner 105 of E0005f2-001. Anyone know what it is and/or how to resolve. Thanks!
E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire E002 Fuser temperature not rising at correct pace, same possibilities as E000 E003 Fuser temperature drops. Same as E000 E004 Fuser problem: AC driver, SSR bad, wire shorted E005 Fuser cleaning web, or problem with sensor, lever or connector. Service mode 6 is the probably reset for this E006 Fuser feed connector E010 Drive problem. Main motor, gears, etc E013 Waste toner drive problem, or waste toner sensor switch has been actuated too many times E015 Pickup motor power supply. Could be bad motor or motor board, or DC controller E020 Problem with developer unit, toner hopper, hopper motor, connection, sensor or DC controller E030 Total counter E031 Option counter or total counter E050 Holding tray (duplex) home position sensor motor or board E051 Holding tray (duplex) home sensor motor or board E202 Panel locked up, but might be no Код ошибки, scan motor problem E203 Scan problem or scan sensor E204 Scan problem or scan sensor E210 Lens sensor or motor problem E212 Lens sensor or motor problem E213 Scan lock sensor or lock solenoid E220 Exposure lamp regulator board E240 DC controller or composite power supply problem E243 DC controller E400 RDF to copier communication problem E401 RDF pickup motor or pickup sensor E402 RDF belt motor or pulse sensor E403 RDF feed motor or pulse sensor E411 RDF tray sensor or registration sensor E500 Sorter main board or communication with copier E510 Sorter feed motor E522 Sorter push bar motor
Jan 13, 2010 | Canon imageRUNNER 105 Copier
Tip
ERROR codes Canon 6045
Canon 6045 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace, same possibilities as E000. E003 Fuser temperature drops. Same as E000. E004 Fuser problem: AC driver, SSR bad, wire shorted. E005 Fuser cleaning web, or problem with sensor, lever or connector. Service mode 6 is the probably reset for this. E006 Fuser feed connector. E010 Drive problem. Main motor, gears, etc. E013 Waste toner drive problem, or waste toner sensor switch has been actuated too many times. E015 Pickup motor power supply. Could be bad motor or motor board, or DC controller. E020 Problem with developer unit, toner hopper, hopper motor, connection, sensor or DC controller. E030 Total counter. E031 Option counter or total counter. E050 Holding tray (duplex) home position sensor motor or board. E051 Holding tray (duplex) home sensor motor or board. E202 Panel locked up, but might be no code, scan motor problem. E203 Scan problem or scan sensor E204 Scan problem or scan sensor E210 Lens sensor or motor problem E212 Lens sensor or motor problem E213 Scan lock sensor or lock solenoid E220 Exposure lamp regulator board E240 DC controller or composite power supply problem. E243 DC controller E400 RDF to copier communication problem E401 RDF pickup motor or pickup sensor. E402 RDF belt motor or pulse sensor. E403 RDF feed motor or pulse sensor. E411 RDF tray sensor or registration sensor E500 Sorter main board or communication with copier E510 Sorter feed motorE522 Sorter push bar motor E523 Sorter reference wall motor E524 Sorter multi-guide motor E525 Sorter bin paper sensor automatic adjustment problem E526 Sorter bin paper sensor automatic adjustment problem E530 Sorter guide bar motor E531 Sorter stapler motor E532 Stapler motor E533 Stapler inside paper sensor E540 Sorter bin shift motor E550 Sorter power supply E710 DC controller E711 DC controller E712 Document feeder IC failure E713 DC controller, sorter E800 Auto power off circuit problem. Main switch or DC controller. E802 Auto power off circuit problem. Main switch or DC controller.
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 4540
Canon 4540 E00 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
Error E030
Checks: step 1 - Is the wiring from the total counter to the connector J119 on the DC controller PCB normal? step 2 - Replace the total copy counter. Is the problem corrected? step 3 - If the above does not work - Replace the DC controller PCB.
Dec 01, 2009 | Canon NP 6050 Copier
E245 for ir1630
E-245 is for the defective counter pcb. the board is a small one on the main controller that keeps track of the amount of copies the machine has made. this code is normaly seen when someone changes the main board and forgets to switch the counter pcb. it is possible that there is a loose screw on the board.
Jul 31, 2009 | Canon imageRUNNER 1630 Copier
Tip
ERROR codes Canon 4035
Canon 4035 E000 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
on Jan 18, 2010 | Office Equipment & Supplies
MY CANON PHOTOCOPIER SHOW EO30
E030 (The total copy counter fails to operate.)
1)Turn OFF the power, and remove
J104B from the DC controller
PCB. Set the tester range to
x1KW, and measure the
resistance between J104B-2 and
J104B-1. Is it about 500W? NO
Check the wiring from
the DC controller PCB to
the total copy counter; if
normal, replace the total
copy counter.
2)Connect J104B to the DC
controller PCB, and turn ON the
power. Set the tester range to 30
VDC. Does the voltage between
104B-2 (+) and J104A-6 (–) on the
DC controller change from about
24 to about 0 and then to about
24 V when the Copy Start key is
pressed? YES =replace the totalcopy counter.
NO =Replace the DCcontroller PCB
Apr 03, 2009 | Canon NP 6035 Copier
E030 err on statrt
• Total copy counter (open circuit)
• DC controller PCB (faulty)
Feb 06, 2009 | Canon NP 6050 Copier
Control card for our minolta ep2030 was shorted out
You will most likely have to by a new key counter or copy controler. Try to find a used one on e-bay. If you just want the copier to work again. In the cut wires with Minolta two of the wires need to be jumed to close the circuit, so the counter will not lock the copier up. You will have to guess, I don't know what color wires were used? Jump two and see if the copier gets released.
Jan 26, 2009 | Office Equipment & Supplies
An error in NP 6050
E030 Does pertain to the total copy counter.If you have changed the dc controller & copy counter & still get the E030 error, you may have to enter the service mode to release the error. In service mode under *4* (function) advance to the error screen & press the star button. If you do not know how to get into service mode you can email me at bspier@carlsonsupplies.com or call Bill @ 315-701-1279 Please put canon 6050 E030 in subject line in case my email dumps it into the junk folder.
Aug 13, 2007 | Canon NP 6050 Copier
Canon MF8180C Color Laser MFC Printer Logo
131 people viewed this question
old marine
old marine
