Question about Mitsubishi VS-50607 50" Rear Projection Television
VS50607 Mitsubishi My tv started off not turning on intermittantly. Now it doesn't turn on. it's like it isn't getting any power. i checked the outlet and other items work in the same socket.
  • evy42 Apr 15, 2008
    tv just shut off during viewing i tried pressing the input and munu button gor a 2-4 code meaning a vertical lose from the source what does this mean..
  • mitsu50 Jun 14, 2008
    tv showing great picture then it turns off. have to let it cool and then after several attempts it will turn on but the picture has lines and not steady then suddenly it looks great again.
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.....
Posted on Oct 06, 2007
Mitsubishi Model VS50607 just clicks when turned on.
Posted on Feb 06, 2010
SOURCE:
My tv turns but it doesn't show a picture but you can still hear
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 28, 2012 | Mitsubishi WD-60737 60 in. HDTV
When I try to power up my acer aspire M1201 the power button isn't responding
Check to make sure that power is reaching the power supply of your unit. If it is and still does not work, then the issue is with the supply that needs replacement. Common malady.
Jun 20, 2017 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Mitsubishi mb46809 doesn't turn on
Check power supply and any switches needed to power the tv on.
Some sensors fail (EX: thermal fuse) and this will cause a power failure.
Thank you
Jul 07, 2011 | Mitsubishi Televison & Video
No power to tv
these tv's need to be plugged into an outlet to get power to them.
or are there no lights at all, or do you hear a click, or does it start up then turn off, or does the lamp turn on for 5 seconds then turn off.
need more info.
Feb 26, 2011 | Mitsubishi WD-62725 62" Rear Projection...
TV will not power on. prog timer flashers
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 28, 2010 | Mitsubishi CS-35305 TV
Mitsubishi 65" LCD (1080P, DLP) keeps shutting down until it "warms up". After shutting down the power led flashes yellow for a minute or so, at which time I power it up again. This cycle repeats 1 to 4...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV may require service.
Jul 27, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
Mitsubshi vs50607 picture flickers and after some time shuts off and won't turn on for about 1 half hr.
Bad connections on deflection yolks will cause this prob
kinda tricky to resolder but anyone handy with an iron could do it
Dec 11, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi VS50607 Self Diagnosis 2-3
  1. Turn on your TV. If he TV request your secret code press QV and 9 at the same time.
  2. Press menu to view the main menu.
  3. Use up or down key to select "Chip Parent Lock" and press enter.
  4. The on screen display wil ask for your current passcode. Press QV and 9 at the same time.
  5. The on-screen display will now ask you to enter a new code.
  6. To cancel the passcode permanenly, press menu or home.
  7. To change to a new passcode, use the number buttons to enter a new code, then press enter.
  8. You must use the remote control included with thisTV. You cannot use a universal remote.
Oct 21, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
558 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
