Question about SanDisk Sansa Clip MP3 Player
Internal memory almost few with just 153 MB of tunes!
I have about 153 megabytes of music on the 2GB SanDisk yet internal memory says there's 520 MB of disk space left! Shouldn't there be enough space for about 500 tunes and not something like 15? I've deleted anything that looked extraneous (i.e. text notes regarding tunes) but that barely made a dent.
Any help would be apprecated.
  • sfjnk Nov 21, 2008
    I get the same thing: only 520MB of memory. I've tried reformatting, deleting the files using Windows Explorer... nothing works! I can't figure it out. If someone has, please let me know!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
How do i add memory to my player. now it has 2 gb and i want to replace it with 16gb
You can't augment the internal memory, short of replacing the entire motherboard. And if you're going to take the innards out of another Sansa, why don't you just use that other Sansa instead?
You can add memory in 2GB chunks by using microSD cards. Photos and videos must be in the 2GB internal memory, but any music you put into a MUSIC folder on the card will appear and play on the Sansa. By putting different albums (or sets of albums) on different cards, you can easily switch between them.
Be sure you use microSD cards, not microSDHC cards.
Feb 19, 2011 | SanDisk Sansa e250 MP3 Player
To get the camera to play from 2gb to 8gb.at 2gb it will play about 40 mins.
its because you have the camera set to store the video in the internal memory not the SD card you have to change the settings so it will save into the SD card instead of the internal memory
Dec 09, 2010 | SanDisk 8GB microSDHC Memory Card with...
Says" not enoughh space for music db please free 8 mb" wont let me put music on or delete
Try removing the microSD card then delete something from the e250's internal memory to free up 8MB.
Feb 07, 2010 | SanDisk Sansa e250 MP3 Player
How many minutes does it's 64 mb internal memory hold? It says it has a 64 megabyte memory without an sd card.
The internal memory included in that device isn't going to be good for more than a minute or two of video recording. Because of the detail required in video capturing as well as the audio feed that it has to record, the file sizes can get quite large. I would recommend grabbing yourself at least a 2GB SD card, and actually probably even a 4GB if you were looking for some longer record times.
Thankfully, SD memory has gone down in price CONSIDERABLY over the years, many retailers often have 4GB SDHC cards for $20 or less.
Hope this helps!
Dec 09, 2009 | Polaroid DVF130 Camcorder
Kodak EasyShare cx7300 says Internal memory full. How to fix?
Your picts go to the memory card correct ? How does the internal memory come into play here - can you select which it's storing on as this sounds like the issue. I would buy a 1gb or 2gb memory card for 30$ and you can take ~ thousand picts :-)
Aug 06, 2009 | Cameras
2gb SanDisk Micro SD Card only holding 500mb.
I believe the Drive has gone Bad. It does happen where the system thinks th e whole drive is there, but the internal hardware just cannot access it.
Aug 07, 2017 | SanDisk 2GB microSD Memory Card
Says i need to free 4mb of space
You need to format the device:
Format
This will format your Sansa c200 player’s internal memory
1) Select Settings from the Main Menu.
2) Select Format
3) Select Yes to format the internal memory or No to cancel.
-Tha Mp3 Doctor
Nov 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Internal memory
Sorry, most Canon cameras do not have internal flash memory (maybe the newer models? But the A70 definitely does not). Those other model cameras that do have internal memory only have a few megabytes. And this memory is primarily intended only to take a couple pics to verify that the camera is working properly.
May 14, 2008 | Canon PowerShot A70 Digital Camera
Sync to player and memory card without duplicates
I got this from:http://www.livedigitally.com/2005/06/27/sandisk-sansa-e130-the-micro-version-of-the-ipod-mini/ Create two playlists with names such as 1. SANSA Internal and 2. SANSA 2GB (assuming your SD card is 2gb). Load songs into each playlist. Edit the sync properties for each drive to only sycn to those playlists. Sync!
Feb 08, 2007 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
