Question about Yamaha DVD-C750 Multi-disc DVD Player
Lens fell out on Yamaha dvd-c750
While looking inside the dvd I noticed that the lens had fallen out of place. How can this item fall out of place? How can it get fixed or you recommend taking it to a repair shop?Do you think this a warraty item?
0 characters
1 Points
What's your problem?power button came out
Hello...I have a suggestion for you...If this is a new player..I't should be under warranty...If the power button fell need to return it because to me...This indicates a factory defect..and trying to put it back in would involve removing the front panel at the very least...which would likely void the warranty and/or cause further damage to the unit...and the way I see it...if it fell out'll fall out again...It is defective....I know how you feel about returning items but the warranty is for your protection....Word to the wise...return it and get a replacement...DON'T OPEN THE UNIT!!!!!...I hope this was helpful...PEACE..
Feb 01, 2012 | Philips PD9012/37 DVD Player
Dvd will not run
You set has a possible failure of the optical head , which could have gone weak. First of all you need to open the set and look inside the tray that holds the CD. If you notice there is a small eye like lens that sticks around a black module. Use a good cotton swap to gently clean this lens to poilish it with care. Thereafter after cleaning connect the set and put in an original cd that has no scratches. If you have an head cleaner try to use it provided it is of a good quality. If this does not solve, then I sugggest that you will need to replace the optical head. You will have to take out the optical head unit after disassembling the mechanism. Procure the same type spare from an authorised centre. Using a non static soldering irron remove the bridge across the PCB before you install. If you are not familiar seek expert help as an inexperienced work might result in failure of the sensitve device. after fixing the spare , replace all the removed parts carefully. Now you can test. I hope my adivce helps. Good Day
Jul 08, 2010 | kawasaki PVS32801 Portable DVD Player
Yamaha DVD S540 stops playing at 1H:15M.
Its abnormal for every Disk to stop playing after every 1H:15M.
I believe there is a setting on your DVD player that need to be adjusted.
Check the Timer settings on your DVD. You could also check that of the TV.
The fault is not from the lens. If it was from the lens, the disk would not play in the first place or it would crack.
So check the timer settings thoroughly.
Take care.
Jan 02, 2010 | Yamaha DVD-S540 DVD Player
Child tilted 5 disc dvd player with discs in the
unplug the dvd player, now take the screws off the cover there may be 4 to 6 screws around it , from the back of player use both hands and lift the cover off gently .. you will gain access to the dvds DONOT SHAKE THEM OUT!!!!!! take them out gently one at a time... this should solve your problem..
Let me know if this worked
Good Luck...
Dec 23, 2009 | Yamaha DVD-C750 Multi-disc DVD Player
Dvd changer won't play
First have look around see if the discs caused any damage to any of the parts. However you need to be a little clearer on what happens when you attempt to play a disc. For instance does it read the disc? If not perhaps some dust got into the lens area and you might need to clean it.
Dec 14, 2009 | Panasonic DVD-F85 Multi-disc DVD Player
Problems with the DVD-VR375
If discs skip, freeze or doesn't read, along with the recording problem, then it could be a dirty lens. If cleaning lens doesn't fix it the optical p/u assembly will have to be replaced. Make sure the items you are trying to record aren't copy guarded.
Sep 01, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
yes that is very possible. cleaning the lens of the dvd player should happen atleast once a month. it can also be that the lens itself is scratched or the lase does not reach the disk tracks due to dust or bad handling
Mar 29, 2009 | Toshiba SD-5000
Where is the lens?
if u mean laser lens its inside the player, some places sell lens cleaning stuff
May 17, 2008 | Sony DVP-NS55P DVD Player
Yamaha DVD-C750 Multi-disc DVD Player Logo
Top Yamaha DVD & Blu-Ray Players Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
