I have a Harman-Kardon FL8380 5 Dics CD changer. The tray did not return all the way and was sticking out about 1/4". I removed the entire table and tray. Boy, what a job trying to re-align the spindle wheels. I do not think I have it aligned properly. Any thoughts on how to do this? I know the spindles have (for lack of terminology) spring loaded arms so that the bottom spindle when it is turning the spring loaded arms will not allow the wheel to only rotate so farm, which controls when the CD is moved in the unit that plays the CD. When I turn the unit on, the tray opens by its self and then returns closed. The front panel indicates "Disc" and flashes. Then the tray opens again after about 10 secs. And the process starts all over again. It is a Harman-Kardon FL8380. HELP!
  • 231 Answers
SOURCE: Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Posted on Dec 03, 2007
SOURCE: Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Followup on higlider's problem. Now it has to be turned on ten times before it stays on. Email from Harman Kardon only suggests taking it to an authorized repair shop. It is clear that it is not from speaker short or overheating, because it only happens when the rcvr is cold.
Posted on Jan 05, 2008
  • 1512 Answers
SOURCE: how do you fix a scuff mark on a harman kardon tuner
unfortunately not, the fascias are generally spray painted plastic. The only decent solution is to replace the whole fascia. A dodgy way would be to mask off the area and respray a symmetrical part of it to try and not look like a repair. Short of that, you may just live with it.
Posted on Feb 18, 2008
  • 4234 Answers
SOURCE: rca cd player
The loading mechanism is out of timing. This needs to be taken apart and reassembled. I'll try and locate the instructions for this tonight.
Posted on Mar 20, 2008
SOURCE: We have the RCA RS2767i
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Posted on Mar 06, 2009
Looking for an internal parts diagram for a Harman Kardon CDR2
Where do you live? Sarasota electronic has belts if its wrotten take machine and belt I am in florida
Apr 03, 2013 | Harman Kardon CDR2 2-Disc CD Recorder
Harman Kardon CDR2 2-Disc CD Recorder Left Tray Door sticks
these are not rubber bands they are belts and if you do not apply the proper ones you will ruin the motor, but it is the problem
Apr 01, 2013 | Harman Kardon CDR2 2-Disc CD Recorder
FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
I have a Harman Kardon crd20 and when trying to record i'm getting "no audio" what is the problem? And is it possible to get a manual?
A simple web search, which you could do yourself, for "Harman Kardon CDR 20 manual" finds several.
Look for "no audio" in the manual. It occurs twice.
Aug 27, 2011 | Harman Kardon CDR20 CD Player
The drawer in our Harman-Kardon HD 950 CD player won't go all the way in. It gets to the point where there's about an inch sticking out, then re-opens and tries again. This is a fairly new unit. Is there...
It turned out that a CD had slid past the drawer and into the case of the CD player. Once I removed it everything was fine. I should point out that mine is *not* a 5-disc drive, but a single-disc drive, model HD 950.
Nov 11, 2010 | Harman Kardon FL8385 5-Disc CD Changer
Harman Kardon CDR30 2-Disc CD Recorder both cd
Open the unit, inspect any obstruction, look for the belt that driving the CD tray, if it is loose replace it.
Jun 12, 2010 | Audio Players & Recorders
Describe your Harman Kardon CDR30 2-Disc CD Recorder Problem It's a CDR26 and neither of the drawers will open.
With mine, it was the drive belts for the cd drawers, which were stretched and rigid. Open the case. Remove the 4 screws that hold down each cd drive. Push the drives out enough so you can pull the silver facing off the sliding try by pulling it up. Now you can lift out the cd drives, removing all the connectors as you go. Flip the white plastic slider underneath each drive and you can mechanically open the slide tray. This reveals the little motor and rubber pulley belt that operates the slide tray. If the belts are broken, perished, rigid or something, get something similar from your local electronics parts store (a couple of bucks each belt), and reassemble.
Feb 11, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Harman Kardon FL8350 CD Changer
try lifting the left side of the player, I tried that last night, and it behaves different, in horizontal mode it tries to load each disc before it finds that there is no disc, but when tilted it just scans the slot (with som optical sensor) and finds the slot empty without loading the disc
Feb 25, 2007 | Harman Kardon FL8350 5-Disc CD Changer
