Question about Acer Aspire 3680 Laptop
No power the adoptor is ok but the laptop is blackout can you help me
  • Anonymous Nov 08, 2008
    I have the same problem. The power supply nor battery can turn the computer on. There are no LEDs on either.
  • Anonymous Nov 15, 2008
    My AA3680-2974 is dead too, but the battery led is the only one that lights up with the adapter hooked up. the power button is not working, how do I get a repair manual to start taking apart to check power swicth?
    Laurier
    Problem Solver:
  • 16 Answers
Inside the power connector there should be a pin sticking out. If this is bent or missing, it has to be replaced! Call your local PC repair shop.
Posted on Nov 10, 2008
I have replaced my new harddisk in my dell inspiron n 4010 and then onwards in my laptop no power is getting and even the led which will blink if the power adoptor is placed even not getting if adoptor is...
Try unplugging it as well as removing the battery. Than press and hold the power button for 30 seconds. If this doesn't solve it, their is a very good chance the motherboard on the computer is fired.
Jun 28, 2011 | Computers & Internet
Battery light blinks for a split second then turns off seems like laptop is fried?
it means that the battery doesnt have much power try to change the adoptor it seems like ur adoptor is not doing its work and if possible try to use a different battery just in case if the battery is at fault
Dec 24, 2010 | Computers & Internet
Does my ASUS N61JQ-X1 have a dual voltage switch for 110v to 220v and/or vice versa? I don't visibly see any.
notebooks or laptops do not have the switches it totally depends on ur adoptor ... if u are using 110 power the adoptor has to be capable of that and if 220 than too the adoptor should be capable , in the market now aday u get adoptors which handles multiple settings ... best way is call asus cust care and ask them if they have something for it or not if u want u can buy it from them or locally places like best buy and wal mart ... if u have purchsed it in US its bond to support 110... totally depending on the country wher u bought it
Dec 09, 2010 | ASUS N61JQX1 Notebook
Ibm r52 model laptop dead adoptor ok cant turn on with adoptor or battery please help me which ic is responsible for dead
your conector is in order, change it and see if you can get the mashine to work after that, will need to be desasembled, and put together again, big job...
Jun 14, 2010 | IBM ThinkPad R52 Notebook
Monitor does not come on (screen is black) Wife turned off everything was fine now can't get back on. Is there some sort of lock on these units?
dear friend,
please do some activity to conform the problem in your laptop, veryfy while you are pressing the power button after some time, press the num lock or cap luck switch is it working means the light is blowing or not? are able to listen the windows start sound? then connect a external monitor and try to swict the vdo on it? if yes then it is the LCD problem and you need to change the LCD assembly. if no then try the following steps:
1: veryfy your adoptor light is glowing or not? if yes then go to next step, if no then replace the adoptor.
2: remove all the external connection, remove the battery from backsite. remove the power adoptor. press the power button for 2min. then connect the battery, adoptor and try... if no then follow below
3. then try to on the laptop by pressing fn+power on botton. try to refix the ram. is there any LED is glowing or not..........?if no then you need to change the mother board
Jan 19, 2010 | Dell Inspiron 6400 Notebook
Everytime i turn it on,it will authomatically shutdown.
See if this helps
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Dec 29, 2009 | Dell Inspiron 6000 Notebook
I have a Gateway 4525GZ power problem
your ac adoptor is not correct it is low amh
please check for original adoptor
Jul 30, 2009 | Gateway 4525GZ Notebook
I am repairing purson in pakistan. and my client laptop have a problem in his charging side, when we connect the New adoptor to charge the Battery of Laptop after some time the power adoptor goeing to...
shortage you need to change the dc jack connector... because is chortage that one if did not replace the dc jact connector.. the same at all even you use the original adaptop or battery
Jun 26, 2009 | HP Compaq nc6120 Notebook PC
Acer aspire 5570 no power
This problem usually occurs if your laptop undergoes any shock or it falls.
The processor of the laptop hangs and needs to b reprogramed by experts in service center.
Same problem happened to my Toshiba A100
Don't forget to rate my solution Plzzzz...
Nov 17, 2008 | Acer Aspire 5580 Notebook
Power problem in monitor
This type of problem generally occurs when adoptor stops working and battery goes down. Show first of all check your power adoptor, its working or not, to check-out remove battery and use power adoptor then try to boot. If there is power led on means adoptor is ok otherwise try to reconnect and also check whether the power supply is ok for adoptor. For canfirmation use another adoptor.
If above not working then you can try to these steps:
1. Remove Power connection (Adoptor connection to Laptop).
2. Remove battery.
3. Re-Connect power to laptop.
4. Make switch on.
If above does not work then after step 2 try the followings
A. Press and hold power button for abt 20-30 secs. keep holding on and insert Power connection now if power led get on leave the button. After that it should on.
If all above didn't solve your problem, then its time to take tour of service centre.
Thanks and Good Luck
Iqbal
Aug 16, 2008 | Dell Vostro 1500 Notebook
Acer Aspire 3680 Laptop Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
