Question about Aprilaire 700 Humidifier
Aprilaire 700 problem
Hi dbuelke! I am having the same problem you posted earlier and fixed. When you mention checking continuity on the H terminals, was this with voltage to the unit (R/C terminals) supplied or without? My unit worked fine for 3 years, and this winter is not operating. R/C has 24 volts and the green light blinks normally when in test, but no voltage shows on the H terminal when in test or when operating. Do you know if this should be 24 volts when the unit is placed in test or some other value?
I can't exactly recall--once I fixed it, I erased it from my memory! However, you need to have power off to check continuity; at least on my meters I'll blow its little internal fuse if there is any voltage. As I recall, one of the main indicators for switch failure was that the switch failed to click/engage. Hope this helps. I was able to contact their tech services to get advice.
Posted on Nov 02, 2008
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Aprilaire 700 fan not working...solenoid is okay. can i test somehow to find problem or replace fan component causing problem? thanks!
yes u can test take the wires and touck one lead to ground and the other to one lead and see if it grounded then if not check continuity thru the 2 motor leaads just touch ur red meter lead to 1 wire and the other lead to the other motor wire and see if u have continuity if not then u have a bad motor and u can take it off and go to a supply house and get one
Feb 26, 2010 | Aprilaire 700 Humidifier
My Aprilaire humidifier is leaking water. What causes this and how do I fix it?
Hi check inside might need cleaning check connetions is drain pipe clear could be blocked filter
Jan 31, 2010 | Aprilaire 700 Humidifier
Instructions manual seems to imply that two 24 Vac (10VA) transformers are required if the HUM or ECA terminal is used to power the automatic digital control. HUM or ECA terminals are 120 volts. The...
No, you do not need another one. Wire everything just as you see it in the wiring schematics and you will only need the transformer supplied with the unit.
Heatman101
Jan 25, 2010 | Aprilaire 700 Humidifier
How close to heating coils to mount aprilaire 700
Hi google your humidifier can down load how to fix this in correct postion
Jan 22, 2010 | Aprilaire 700 Humidifier
I need to change my Aprilaire 700 from *automatic* to *manual
Hi google aprillaire you can donwload manuals for this
Jan 09, 2010 | Aprilaire 700 Humidifier
Aprilaire 700 using too much water-------
There is a small oriface that is installed next to the solenoid valve. It sounds like this oriface is missing. It reduces the water flow through the humidifier when it is working properly. You should be able to disassemble the solenoid fittings to check and see if the oriface is in the water line. For a "temporary" fix regulate the water pressure down by closing down on the saddle valve.
Good luck
HVAC Teacher
Feb 25, 2009 | Aprilaire 700 Humidifier
New Aprilaire 700 - loud hi pitched whistle
You may be having problem with air scaping from the base of the hum. it will probably may have to put silicone around the base of the hum. to stop the air scaping.
Feb 05, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 operating at wrong time
You want the humidifier to run in heat mode which is the r-w1 terminal on the stat.
Nov 17, 2008 | Aprilaire 700 Humidifier
Leaking humidifier
Check for an obstructed drain line.
Feb 28, 2008 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
145 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
