Question about Carver PM950 Amplifier
Marantz PM-34 Problem
I have an amplifier marantz PM-34. this amplifier work very well for about 12 years. but sudenlly two days ago, when it works, it turned off. after that i check it and i found its fude broken. i bougth a fuse with that characteristics. but after installing new fuse, the amplifier smelled, in the main circuit, there is a triple based component, which i guss it is a resistante, because it named R23 and on its body printed R0.18ohm. this component is dual (i think one for left and other for right). please help me that is the problem is due to this component or maybe some other component has problem. I see precisely other component, but there is no visual defect. unfirtunately in my countrey, there are no marantz agency that i cen refer.
  • 1,512 Answers
Hi there
The part that you speak of is called the emitter stabilizer resistor. It is common to the output pair on one channel. You will find that the large "output" transistors mounted to the heat sink either side of this resistor will most probably be faulty.
Best not to run the amp at all whilst in this condition.
To be sure that you have an effective repair, you will need to change both these parts, and also the "driver" transistors that connect to the outputs. They too are in symmetrical positions close to the the output transistors. You should also check that the 3 legged resistor you mentioned is measuring its correct value, and check all other low value resistors in the output stage area to that channel.
If you are not familiar with repairing this sort of equipment, perhaps you can find a repair guy with some experience on audio equipment, then this work should be all he needs to do to repair the amp. I would also ask him to "blanket resolder" the output/bias stages and power regulator stages in the amp as problems with heat stressed cracked/failed soldering and dry joints often cause these amps to blow the output transistors.
BE SURE THAT THE CORRECT PARTS ONLY are used for the repairs. Different transistors could cause future problems with the amp. The parts can be obtained relatively easily from a marantz distributor(we can find one in a country near to you). OR if you can give me the markings to each of the parts you need, I can provide you with an international source to get them from.
The amp is decent HiFi, and worth repair. Happy to provide you any assitance I can, Good Luck
regards
robotek
Posted on Nov 03, 2008
Can i connet my marantz ki17 amp to a power amp
Hi, i don't really understand why you want to connect an amplifier to an amplifer.
Might be that you want to get a louder volume or ?don't know.
I don't think there is any need for you too connect marantz ki17 amp to a power am. Both do the same work, but might have different watts.
So you will need to check what you want to connect with the amplifier first and check the watts that can carry it without interference from the amplifier.
I guess that would do the magic.
Have a nice day.
Feb 18, 2011 | Marantz PM-15S1 2-Channel Amplifier
Marantz pm 7200 lost sound, only works when volume is up high, still looks like there are no high or medium frequencies.
You have either lost the pre-amp stage or the Main Amp stage. Since you have a problem on both channels it most be a part that is common to both channels. Something like an IC I would suspect.
Oct 31, 2009 | Marantz PM7200 2-Channel Amplifier
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Jul 31, 2009 | Marantz PM-15S1 2-Channel Amplifier
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
How do I connect a subwoofer to an amplifier marantz pm-68
double up the speaker and then use the two extra screw to hook sub and center
Feb 10, 2009 | Marantz PM-68 Amplifier
Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
Dec 21, 2008 | Marantz Audio Players & Recorders
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
Marantz pm 7200
Could be a power supply failure or a Power "On" switch failure.
Kev
Feb 23, 2008 | Marantz PM7200 2-Channel Amplifier
805 people viewed this question
Top Carver Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
jeff5may32
Are you a Carver Audio Player and Recorder Expert? Answer questions, earn points and help others
