Question about Tascam 2488 Portastudio Multitrack Recorder System
Tascam 2488 Hi i have a Shure SM58 mic with a XLR end how do i hook that up to the Tascam 2488 My email is gator48@ptd.net
    Novelist:
  • 189 Answers
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
Posted on Dec 01, 2008
Whenever i hold my shure mic there is this humming sound coming out of my speaker
You have a bad cable or incorrectely wired cable. The cable should have XLR connectors both ends. Verify that like numbered pins are connected end to end. The shoeld lead on pin 1 of the connectors is probably broken at one end.
Sep 13, 2011 | Shure SM58 Professional Microphone
Iam having probloms geting my microphone to work and having a problom hooking up my speakers
this model needs to be hooked up to an amplifier for speakers to work..it has no audio amplifier inside...as for the mic's..you'll need to make sure you have the mic inputs that you are using selected in the setup menu..there are the xlr{3 pin} connectors and the 1/4" connectors..check the setup
Jan 08, 2011 | Tascam 2488 Portastudio Multitrack...
Shure sm58 mic stopped working ...
Check the wire connections where the xlr cable connects.
Apr 12, 2010 | Shure SM58 Professional Microphone
Shure sm58 just started outputting very low volume. It has been working fine with our system for years. Tried other sm58 mics on the same mic cable with same system setup and no troubles. There is still...
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Apr 04, 2010 | Shure SM58 Professional Microphone
Where to buy a the swivel adapter for shure sm58 and shure wireless lx2 sm58
You can buy the swivels from Beyer, they have several sizes.
In my opinion he best you can get.
Regards,
Gerard
Jan 05, 2010 | Shure (LX287CC) Professional Microphone
My husband and I just purchased tascam 2488 portastudio, we are truly novice and need help with figuring out what cords are needed to connect the mics we have to the tascam. We would also like to know is...
If your mics are XLR (a hole on the bottom of the mic with three pins visible in it) you will need one of these for each mic, plugged into one of the four channels on the tascam that has an XLR connection (which will be the female version of the connection on the bottom of your mic). If your mics have a 1/4-inch connection, you can use the 1/4-inch connection on any channel on the tascam. For the stereo connection, you will need one of these of sufficient length to convert the RCA output from your stereo to the 1/4-inch input on your Tascam. Find "Tape Out" or "AUX Out" on your stereo and plug in the RCA side of the cable there (note which color you use for R and L). Use the 1/4" end of the cable to connect to two available channels on your mixer. Use the Pan knob to pan the left channel to the left and the right channel to the right, and voila! Hope this helps, and good luck!
Nov 13, 2009 | Tascam 2488 Portastudio Multitrack...
I cannot hear myself on the microphone shure sm58
What sort of a preamp are u using this needs to be plugged into the lo impedance XLR input (this is a lo output dynamic mic 1.85Mv out)
The XLR should be input pin 2 return (gnd) pin 3.This mic does not NOT use phantom power (48v) if it is a dual input (pin 1 48v) source make sure the phantom power is turned of.
If this is being done then there maybe a problem with the mic.
You can check this by plugging a source in to the input to check that it is working line out from cd player midi or some other source.
biinary 6
Sep 16, 2009 | Shure SM58 Professional Microphone
Shure 87a no sound
Send the mic to Shure for repairs. www.shure.com/service
Sep 12, 2009 | Shure Beta 87A Professional Microphone
Lost user guide sm58 wireless mic
The User Guide can be found on the Shure website.
Dec 19, 2008 | Shure ULX Standard Series Wireless...
Connect yamaha keyboard to tascam 2488 MKII
There are 8 inputs on the back. 4 of them support XLR type microphone connections, but also double as 1/4 inch and the remaining four are just 1/4 inch. These are all line level inputs and you can use any of them for a keyboard hookup. Typically you might leave the XLR inputs (A thru D) available for mics and take the next two (E and F) to use from your keyboards L and R outputs. Then just assign those inputs to two adjacent channels (tracks) or one of the stereo pairs, turn up the input levels for those inputs and the faders for those tracks and you'll be able to hear the keyboard playing through the 2488 (or whatever monitors/or stereo you have hooked up to it for monitoring). To record the keyboard simply arm whatever tracks you have those inputs assigned to for recording and record away.
bd.
Oct 30, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
124 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
