Question about Tag Heuer WAF2110.BA0806 Aquaracer Automatic watch
Just want to ask about my new tag heuer watch???
First of all i have a new tag heuer watch its an automatic self winding watch, my question is, is it normal to hear a soft sound when you wound the watch manually? Second, can you pls. recommend a watch winder since i do not use my watch on a regular basis. Your help would be highly appreciated. thanks in advance.
  • 2,334 Answers
Yes. it's normal to hear that soft noise when winding manually as all the gears gets engaged.
I would recommend watch rotator (winder) by Wolf Designs, Module 1.7, but you can choose for yourself.
Here is a link to Wolf Designs:
Don'y forget to rate, please.
Posted on Jan 09, 2009
The winding knob does not lock when I press and turn
That means you need a new stem. Stem problems are fairly common on Quartz Tag Heuer watches. Should not cost you more than $100.
Nov 10, 2013 | Tag Heuer WAF2110.BA0806 Aquaracer...
How do I wind up my tag carrera automatic using the crown??
Wow, how wrong yall are.
There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
Feb 24, 2011 | Tag Heuer Automatic Chronograph Series...
My problem is all of a sudden I have to wind up my watch every morning after it sits on my bedside table over night. It is meant to last over 24 hours without having to wind it up but this all of a sudden...
your watch might have to be serviced. If you are manually winding your watch thats not good at all because it puts unnecessary rapid stress on the sensitive auto reverser wheels possibly damaging the tiny internal clicks. The torque pressure resulting from manual winding of automatic watches is not made for, day-in day-out, manual winding, especially if the watch is not in a pristine new or overhauled condition. It is better to buy a watch winder to keep your watch running.
You should get it looked at by a watch maker who is very qualified or send it to Tag Heuer to get serviced they will give you a quote on how much it will cost before repairing watch so you may decide if you want to go through with it or not.
Sometimes its simple things such as needing lubrication or cleaning. An automatic watch should be serviced every 5 years anyways. So best advice is to get it checked by a well trained professional. My watch guy is great and really cheap . I would ask around make sure you are dealing with a master watch maker though.
Oct 15, 2010 | Tag Heuer Automatic Chronograph Series...
Tag Heuer Tiger Wood Golf WAE1111.FT6004 Watch stops when not worn. Is there a problem
An automatic watch needs to be worn, wound daily or placed on a watch winder to keep it going. It is not like a quartz watch that has a battery and can keep going when not worn. A modern automatic watch will run for about 36 - 48 hours on a full wind.
A quartz watch that stops like you describe is in need of a cleaning by a professional watchmaker. When this stopping occurs it is an indication the oils have dried out and the warmth from your body heats them so they are semi liquid again and the watch runs. but when the watch cools again the oils harden and the watch stops.
Hope this helps,
Yellowstone Watch, Inc.
May 21, 2010 | Tag Heuer Tiger Wood Golf WAE1111 Watch
I have a tag heuer aquaracer crono automatic and i can hear it and feel it when its self winding is this normal?
this is normal if you didnt i would be worried..all automatics do this its the rota in the back theres no such thing as a silent automatic in the trade we call them swinging bricks..
Mar 23, 2010 | Tag Heuer Aquaracer Chrono Automatic...
New Tag Aquareacer Automatic wont manualy wind
If thats a new watch then there could be an issue in the movement and its possible it could be covered under warranty. Take it back to the store asap!
Jan 15, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag heuer automatic series, how do you start the watch after purchasing?
push the crown in if it is in the adjust position .then shake the watch around the auto mechanism sould start the watch
Aug 23, 2009 | Tag Heuer Automatic Chronograph Series...
Dont know how many time to wind it
until it begins to feel just slightly taunt,Do NOT over wind a wind-up wrist watch, if its a self winding you should just have to walk in it to wind it. here is a link to a pdf of your manual which has winding procedures, Good luck Jon click here
May 21, 2009 | Tag Heuer Aquaracer Chrono Automatic...
Tag automatic watch = stopped working
Stop shaking it!
You could try wearing it and it should wind itself with your body motion or...
your could manually wind it (setting 1)
Jan 22, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag Heuer Button Popping Out
If that buttun is pushbutton, then the fixing stopwasher has come off (inside watch).
If you meen the crown (winding and setting button), then setting lever or setting lever spring is damaged or broke.
Find your nearest watchmaker as both need professional repair and parts.
Dec 22, 2008 | Tag Heuer Link Automatic Chronometer...
Tag Heuer WAF2110.BA0806 Aquaracer Automatic watch Logo
978 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
