Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Maikita bhp 451 transmissions - Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
  • 3 more comments
  • ben_kash Nov 02, 2008
    The transmission is toast on my drill and I didn't punish it at all.  This is the third time this has happened since I purchased this tool.
  • Anonymous Nov 21, 2008
    it makes noise and it doesn't turn
  • dwoodman Dec 01, 2008
    same problem for me. I tried the standard tricks to remove the chuck but nothing works.Any suggestions?
  • Anonymous Dec 05, 2008
    3rd gear doesnt spin when pressure is put on it
  • ben_kash Mar 10, 2009
    I had  to get creative I bought a new drill from Home Depot returned the tool and used the new reciept to get the repair with the improved trans.
The gearbox is good,what the problem is,is the nylon speed change ring that goes on the outside of the gearbox that takes the power of the gearbox,the end of the teeth,about 2mm or less strip making only noise when in 2nd or 3rd gear,,they sell it with the new gearbox and charge you,,,,,but you can buy it separatly,,,the part no.419558-2,,pick key 01820914
Posted on May 21, 2010
  • donna_ch8 Aug 26, 2010
    If you have repaired your BHP 451, could you tell me where the 2 small pins go when reassembling it? We can't find any gear assembly diagrams
  • Mani kurian
    Mani kurian Dec 03, 2013
    it goes on the plastic ring which has the speed selector.
Yer Makita 451 is doggy tool i have 3 with gear box problems. Duds
Posted on Nov 27, 2009
  • Mani kurian
    sell it on e-bay, can get up to 15.00 to 20.00 pounds.
I had the same problem with my 451, after some research and with a exploded parts list i found that makita have an improved replacement gearbox assembly, The part number is 125430-5 Gear assembly and you will also need to replace the change lever, part 125435-5 total price inc delivery was $91.80 inc delivery from Syd Wilson electrics. syd2@iinet.net.au.
Posted on Dec 21, 2008
You also might want to consider just buying a new drill-only replacement (currently $118.80 at Tyler Tool: tylertool.com/makita). Comes with a new three year warranty, so you can send it back to be repaired by Makita next time.
Posted on Mar 10, 2009
Please tell me the engine specification of Tata Nexon. Does it is coming in the automatic as well as CNG version in India?
Tata Nexon is the subcompact 4-metre SUV from the Tata Motors, which has created a lot of buzz even before its launch. I don't expect the Tata Nexon gets a CNG kit and it only offered 6-speed manual transmission. Here I specify some of the Tata Nexon specifications, have a look
=> It is available in both the engine. The petrol variants carry 1.2-litre Revotron which produces 110 bhp of power & 15-17kmpl of mileage while diesel have 4-cylinder 1.5-litre Revotorq engine which makes 110 bhp of power & 21-23kmpl mileage.
=> 6.5-inch touchscreen infotainment system, automatic climate control, dual front airbags & reverse parking sensors
=> Three drive modes Eco, City and Sport
Sep 12, 2017 | Tata Cars & Trucks
Looking for a wiring diagram for a range selector sensor plug for a 2004 chevy silverado 1500,4x4,4.8L with a 4KCD transmission
Connector Part Information • 15416722 BLK
• ASM Conn 12 F GT
Pin Wire Color Circuit No. Function
1 DK GRN 1433 Clutch Start Switch Signal
2-3 -- -- Not Used
4 YEL 772 Transmission Range Switch Signal B
5 BLK/WHT 771 Transmission Range Switch Signal A
6 GRY 773 Transmission Range Switch Signal C
7 BLK/WHT 451 Ground
8 WHT 776 Transmission Range Switch Signal P
9 LT GRN 275 Park Neutral Position Switch Signal
10 GRY 1524 Back-Up Lamp Supply Voltage
11 PNK 839 Ignition 1 Voltage
12 PPL 639 Ignition 1 Voltage
This all I could find, hope it is the correct one.
Apr 08, 2016 | Cars & Trucks
What transmissions are compatible with 1991 chevy silverado 1500 extra cab
Have a look on Ebay:
http://www.ebay.com/bhp/chevy-silverado-1500-transmission
Mar 13, 2016 | Chevrolet Silverado 1500 Cars & Trucks
I am thinking about buying a garmin 451 chartplotter, can I connect this to my garmin 160c fishfinder for sonar capability?
Hi James!
According to the owner's manual, the 451 can be used as a fishfinder when connected to a transducer. I would contact Garmin directly to see if the ducer from your 160c is compatible with a 451. If it is, you're in business! You'll likely have to cut/splice cable, but it'd be far easier than replacing the thru-hulls. (The 451 does come with transducers.)
It has been my experience that Garmin is REAL good when it comes to answering questions from consumers.
http://www.garmin.com/us/support/
Dec 26, 2014 | Garmin Boating
Coil wires firing order
you pulled them all at once.?
its really a Daewoo Lacetti
and all these engines.
pick an engine
1.4 L 93 bhp (69 kW) Petrol I4
1.6 L 109 bhp (81 kW) Petrol I4
1.8 L 120 bhp (89 kW) Petrol I4
2.0 L 132 bhp (98 kW) Petrol I4
2.0 L 121 bhp (90 kW) Petrol I4
2.0 L 121 bhp (90 kW) Diesel I4
Nov 06, 2013 | 2004 Suzuki Forenza
How do you take the chuck off makita bhp 451
After removing the screw lock the short end of a 3/8" to 1/2" allen wrench in the chuck. Firmly hold the drill on the edge of a bench or lock it in a vice so you can strike the allen wrench hard and fast. The screw is reverse threaded but the chuck turns lefty loosy like a regular nut and bolt. It's the best and only way to break the chuck free.
Sep 06, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
I have a 3 cyllinder engine havin 34 bhp wan to increse15bhp more
The only thing that would give you more power without hurting fuel mileage would be a turbo charger. Any other method would decreas mileage.
Feb 28, 2010 | 2000 Suzuki Aerio
Is the power of 58 bhp at engine sprocket or wheels...cos it really doesnt seem that much to me...
its measured at the flywheel, but then you get losses through transmission, chain wheels etc
Feb 18, 2009 | 2004 Yamaha YZ 250 F
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
4,572 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
