Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3 front loader door cracking and broken latch problem
We have had the kenmore H3t elite for 6 yrs. and have had continuous problems with the front dor - the plastic keeps cracking and breaking. the dor was repaced once about 3 yrs ago by sears at no charge (out of warranty) after much arguing and negotiating and less than one month after it was replaced it began to crack again - no more help f rom sears and now the door cracked so badly that the plastic got stuck in the latch and the latch broke as well - whcih means the door doesnt work at all- any one else with this problem?? any suggestions?? is it worht fixing - the machine is in a laundry room in our basement. and i am very careful not to let anything bang into it etc. we are thinking of just ditching the machine but the others we are looking at all seem to have problems of their own -
  • 1 more comment
  • danielrclock Dec 08, 2008
    I have the same problem. Sears is worhtless in helping. They want us to buy another extended warranty. We had it three years. We've preplaced it three times and it just broke again.
  • buggles23 Mar 20, 2009
    It happened to me today!!!! WHAT SHOULD I DO!!!!! HELP!!!!!!!! VAL.ARCA@LANGNEWS.COM
  • chmiller Apr 07, 2009
    We have had f11 and dh codes for the last 8 months on our 4 year old machine. Repairman to the house 4 times and it doesn't change things. I have spoken with Sears and they are willing to offer a 10% discount if we purchase a new one from them. Riiiight.
  • 63 Answers
There around 300.00 1 ideal to share buy service smart agreement from sears all parts &labor will be covered up to 500.00 i have warranty it payed off big time
Posted on Nov 14, 2008
Kenmore washer HE3 broken door latch. How do you replace
Unplug unit then You can open the door, then remove the spring loaded clamp that secures the door boot (rubber) to the front panel, carefully pull the door boot away just where the door latch is (no reason to completely remove) remove the 3 screws securing the door latch to the front panel..Then reach behind the panel and pull the latch towards the opening the give just enough wiring to do so undo the 3 wiring connectors to the latch assy. then pull out the rest of the way Reverse the procedure to reinstall
Dec 29, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hi there, I have a Kenmore Elite H3t and wanted to do a load of laundry today and it keeps blinking in Red DL and then F. I looked through my manual in the troubleshooting area and of course that...
Hi
Thanks for using FixYa. Error "dlf" means a door latch failure. This means that you'll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it's unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 08, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore he3 dryer door keeps opening when operating. Thus stopping the drying process. What should I check and replace?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The door latch is broken...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 08, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
How do i replace kenmore washing machine latch
I'm assuming you are referring to the door latch assembly. The following link explains step-by-step how to replace the door latch on a Kemore Elite front loader:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How to replace door lock on my kenmore elite washer he3
The following link explains step-by-step how to replace the door latch on a Kenmore Elite HE3:
This is a very simple repair. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite dryer runs cold no heat
Most of the time its the thermal fuse part # 3390719
Jul 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
351 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
