Question about Aprilaire 700 Humidifier
Not operating-controller questions
I have a model 700 with the automatic controller. It has operated fine for 3 years, but just changed to heat 2 weeks ago and is not operating. I checked it in test mode and nothing happens other than the controller green light blinks as is normal for test. The solenoid does not click, no water appears and the fan does not run. I checked voltages and the R/C terminals have the correct 24 volts. There is no voltage to the unit from the H terminals, whether idle or running in test. the ODT terminals show 5 volts. Should the H terminals show 24 volts when in test mode to activate the humidifier? I suspect the controller is the issue. Any fixes or just replace?
  • Anonymous Nov 23, 2008
    Model 700 automatic controller is not working. It just clicks but does not power the fan or actuate the solenoid. If you bypass the controller the ubit works fine. Has worked for two years. I actually have two units with auto control and both are not working this year. Aprilaire said I need new controllers. Seems fishy that both go at the same time. Thanks.
  • harryjjackso Nov 25, 2008
    My controller does nothing
Are you having problems with your fan blade rotating in the wrong direction? Is yours pushing or pulling water through the water panel? I am very unhappy with my humidity levels in my house.
Posted on Nov 23, 2008
Replaced water panel and the light keeps blinking to change it agai...model 700
Sorry to read about your problem, I hope this helps you out.
did you hit the reset
Digital Humidifier Control (Model 700): (Automatic or Manual mode) Check system operation and reset Change Water Panel indicator by setting the knob to "Test/Reset". With HVAC blower operating and HVAC calling for heat, humidifier will operate for one minute. DO NOT LEAVE IN TEST MODE AS HUMIDIFIER WILL NOT OPERATE.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 29, 2010 | Aprilaire 700 Humidifier
I have lost my manual. readout on the digital display is CF. humidifier operates fine. what does the display CF mean?jiml@suddenlink.net
It means Change Filter.
However, assuming that you have done that in the recent past, you probably want to know more. I'm not sure how this actually works (that is why it shows CF). I saw it for the first time after 2 or 3 years of using my humidifier. (And I had just changed the filter a week or so previously).
You may have to turn the unit off/on or even unplug it to clear the message, then it should operate normally.
Nov 05, 2010 | Emerson HDC12 Humidifier
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
Research Products Corporation
www.aprilaire.com
Nov 01, 2010 | Aprilaire 700 Humidifier
Change water pad but change water panel light is on
Turn the control knob to the
“Test/Reset” position until the “Change
Water Panel” light blinks to reset the
water panel change indicator timer.
(Blower must be operating and furnace
calling for heat.) Be sure to turn the
control knob back to the prior setting when finished
Oct 27, 2009 | Aprilaire 700 Humidifier
Aprilaire Model 700 - not achieving 40% humidity
if it is set up right, you should be able to run your fan 100% of the time and the humidifier will come on when there is a need for humidity. you can experiment with leaving the fan on and see if this helps. it will run your electric bill up a little and also you will have a lot of waste water. that is a drawback to the bypass type humidifiers. also a factor is if the water supply is hooked up to the hot or cold side. it will humidify better on the hot side, but you tend to get more deposits that plug the solenoid over time and you will be running your water heater quite a bit. 1600 sqft may be pushing the limit of this humidifier.
Jan 24, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 humidifier not adding any humidity
Thanks for your Question,
Sounds to me like you have a calcium build up in the Solenoid, which is restricting flow to the unit for proper operation, you might even have a bit of restriction in the copper line feeding the Solenoid, replacement of the solenoid would probably take care of your problem, one quick tip, in the spring and summer months, its a good idea to shut the water off to the unit, this should make the Solenoid last a little longer, hope this was helpful to ya, please let me know, thanks again,
mr.grzz
Jan 12, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 problem
I can't exactly recall--once I fixed it, I erased it from my memory! However, you need to have power off to check continuity; at least on my meters I'll blow its little internal fuse if there is any voltage. As I recall, one of the main indicators for switch failure was that the switch failed to click/engage. Hope this helps. I was able to contact their tech services to get advice.
Nov 02, 2008 | Aprilaire 700 Humidifier
Water panel light
The reset is to place the controller in the "test/reset" position. The furnace must be in heat mode and operating at the time. The green light will blink for about 1 minute if operating properly, then cut off when placed in a normal setting.
Oct 19, 2008 | Aprilaire 700 Humidifier
Cleaning Light
Either you have a problem with the sensor or the control board. Try disconnecting the sensor and see if it come on. If it does change the sensor. If not it is the control.
Dec 21, 2007 | Honeywell HWM-330 3 Gallon Humidifier
Aprilaire 700 Humidifier Logo
146 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
