Question about Dayton G73 Utility Heater
Installing a Dayton G73
Hi there. I've wired 240 for the garage, everything works on a 15a basis, lights etc. Now I'm installing the G73 heater, and everytime I turn the breaker on in the garage, detached, it trips the breaker in the house. I'm using a 30amp breaker in the garage, and a 40amp breaker in the house. The unit call for 30amps, however on an amp meter, it's tripping in the house on 7.6amps? The red and black wires from the breaker in the garage are wired to the L1 and L2 ports, the bare ground from the garage panel is wired to the ground screw in the dayton unit, and the white wire is not utilized...what am I doing wrong to trip the house breaker? I've tried different breakers, larger breakers...everything trips the house breaker. Please help.
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Posted on Jan 18, 2009
Wiring Remote Thermostat for NewAir G73
Start by reading the manual, it can be obtained at: http://cache.heater-home.com/manuals/newair-g73.pdf
Feb 02, 2014 | NewAir G73 5,000 W Electric Shop & Garage...
I have installed a Dayton G73 heater in my garage along with a 240V outlet. I am using a 3 prong dryer cord and I am having difficulty figuring out which wire to hook to L1 and L2. I have determined the...
here's a link to the install guide
www.air-n-water.com/manuals/G73.pdf
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Installation-Dayton-G73-Garage.htm
Nov 02, 2009 | Heating & Cooling
Where do i connect load wires to 240 volt baseboard heater
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
Oct 27, 2009 | Dayton G73 Utility Heater
Looing 2 buy!!
This is a good application of this type of heater. There are many things to consider as you size the heater though. Insulation, 1,2,3-car garage, insulated garage door, average ambient temp. etc. In most cases of garage heaters, they are used to temper the air from cold to a workable temperature. If this is the case, I'm sure this would take care of most applications of garage heating.
Oct 02, 2009 | Dayton G73 Utility Heater
Wiring
Since it is a 30 amp heater you need to run #10 gauge wire and use a 2 pole 30 amp breaker, since it is 208/240 volts. I hope this helped you.
Jan 14, 2009 | Dayton G73 Utility Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
If that is a 240V unit then you are correct wiring L1 and L2 to black and red. Unless the unit uses 120V for something like a control panel, it doesn't need the neutral.
Jan 14, 2008 | Dayton G73 Utility Heater
Dayton G73 Utility Heater Logo
390 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
