Question about Frigidaire ATF6000ES Front Load Washer
Waser will not spin, belt ok and visually seems to be ok....
Mod # LTF2140E...........all cycles work normal until spin cycle........drains, but does not spin. I have tried all settings and still no spin cycle.
  • fritochipguy Apr 04, 2009
    exact same problem.....
    Sergeant:
    Champion:
  • 324 Answers
Sounds like motor control board could be bad.
Posted on Nov 03, 2008
Water drains but spin will not spin
This can be due to problems in the program cycle as it seems to over ride the program.
This can also be due to fault in the program controller unit , please try this with a separate program, also clean the drain , check the connections to the controller, check for fault in the level sensor.
Jan 01, 2013 | Washing Machines
Frigidaire front loading washer drainage
Hello - Is the washer draining or not draining? If it is not, this particular issue could be caused by a variety of reason. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Oct 01, 2012 | Frigidaire Washing Machines
Washing machine drum does not rotate.
was the waser noisy before it stoped woeking if so it could be your drum bearing or somthing caught in the drum
Nov 10, 2011 | Washing Machines
MOTOR SMELLS OF BURNT MOTOR WINDINGS. iS IT NORMAL
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
http://www.partselect.com/MultiModels.aspx?ModelNum=ALW480DA&searchTerm=&RefineSearch=0
Jan 22, 2010 | Amana ALW480DA Top Load Washer
Pump works. Spins when empty/no load in tub. clutch slips when loaded
If the drive belt is slipping during the agitate and both spin cycles for loaded conditions, I suspect that the drive belt is excessively worn. If it slipped only during a loaded spin cycle, I would have suspected that the sliding motor mount is gummed up and not moving to a belt tighten position during the start of a spin cycle. Since the unit drains with no problem for loaded and unloaded conditions, the pump belt should be OK. Replace the drive belt and clean the dust, gunk, detergent, etc, out of the sliding mount to make sure that it tightens properly when a loaded spin cycle starts. Note that on most models, the drive belt is designed to slip when spin cycles first engage, and they will continue to slip until after the drum has accelerated.
Sep 23, 2009 | Whirlpool LSR5132PQ Top Load Washer
Water won't spin out of clothes
You have a "drain waterpump fault" To fix this the pump must be dis-assembled and, the obstruction blocking the pump impeller must be removed. First obtain a radiator hose pinch-off plier and, a hoseclamp plier from an autoparts store; place the hose plier on the pump hose just below the tub and/or, just above the pump. squeeze the plier until it locks closed; this will pervent the water in the tub from draining when you remove the pump cover. using a screwdriver open the pump and, remove the obstruction in the pump: be sure to cover the floor under the pump, with rags to catch any water still left in the pump.
Jun 09, 2009 | Frigidaire ATF6000ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Wash but no spin
1st of all is there a spin cancel buuton on this machine and has it been activated, or is there a spin speed selector knob and has it been turned down...is inner drum easily turned by hand.if it is ok then belt tension could be suspect (tighten)im sure there is an out of load balance detection circuit on the main circuit board....also is it draining ok because it wont spin until it cant dectect low or no water prior to final spin.....also if it has a programme dial the select a spin programme on another section of selector dial.........hope this is of some help...
May 08, 2007 | Zanussi F1045W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
247 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
