Question about Philips Magnavox 51MP392H Rear Projection Television
Philips rear projection tv-wont turn on
When i plug in the tv push the power button the amber light flashes a couple times makes a click noise then all lights go off and then i have nothing
    Scholar:
  • 33 Answers
Sounds like your Convergence chips failed, were your red/blue/green colors slowly seperating or was the picture starting to curve on the top or bottom or both? if so see below general post.
Also what model # is your TV and what size?
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Posted on Nov 20, 2008
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
Multiple issue,power light flashes
Sounds like first loose connection on circuit board. I would first look around the relay this is what clicks. Then also the low voltage transformers. These problems are always concerns when set is moved or bumped hard. Try this first. Or it could be a heated issue.
Nov 26, 2007 | Philips 50P8341 50" Rear Projection...
TV WONT START UP - RED LIGHT COMES ON AND THERE IS A CLICKING NOISE AS IF IT IS TRYING TO RE START - IS IT THE LAMP UNIT OR STARTER?
if the lamp has gone the bottom light will flash if the top flashes there a problem with the tv there is reset you can do
  • Point the Sony remote control at the TV and press and hold the "Up" arrow button.
  • 3
    Push the "Power" button on the TV while holding down onto the "Up" button. Release the "Up" button when the TV turns off, then turns back on.
  • 4
    Select "OK" when shown the factor settings and the television has completed its TV reset
  • Read more: How to Completely Reset a Sony TV with a Blinking LED ' eHow.co.uk http://www.ehow.co.uk/how_6011902_completely-sony-tv-blinking-led.html#ixzz17Eijjdrn good luck regards shaun
    Dec 05, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
    Tv wont turn on
    I have a Philips 60" Rear Projection, and all of a sudden I have no picture or sound. I push the power button, and all it does is click. It will keep clicking until I turn it off. Anyone seen this problem?
    May 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
    Philips rear projection tv 7 years old 55PP9352..
    when yellow led....push the "P-" button about 5 times then push the left hand square button (looks like square with arrow pointing right) several times until it cycles to the input device.... order is ext1, ext2, ext3, front input, TV....
    Nov 04, 2009 | Televison & Video
    I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
    Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
    Sep 18, 2009 | Philips 60PW9363 60" Rear Projection...
    Tv wont turn on
    your tv is in shutdown mode replacing the power suply module may corect this problem
    Oct 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
    Tv wont power up makes a noise but no picture
    Replace your STKS big black ics 392-020 go to 040s if 119s 150s go to 180s.
    Oct 13, 2008 | Philips Magnavox 51MP392H Rear Projection...
    Green Light Flashing in Power Button
    so the sound of mouse click is from the button being pushed.
    is the light flashing codes at you in the form of flashing?
    looks like you may have a short in the p/s.
    Apr 09, 2008 | Philips 55PW9363 55" Rear Projection...
    Tv power button flashing no picture or sound
    Short in powersupply check secondary fuse and all other fuses too. Were there a color problem before this/ Because most of these set have convergence problems. The amps May need to be changed and resistors around them.
    Aug 25, 2007 | Philips 60P8341 60" Rear Projection...
    Philips Magnavox 51MP392H Rear Projection Television Logo
    218 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
