Question about Kodak EASYSHARE 5100 All-In-One Printer
Ink i just installed a new black ink and is doesn't work. the printer info is showing that the black ink is full but when i print something in black, it doesn't work.
  • Anonymous Apr 02, 2009
    the black ink is not working i replaced the cartridge and it still doesn't work
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
You can use the kodak interactive site to fix this issue, just follow the steps there to take care of this problem
Go to www.kodak.com/go/itg missing colors for sub class
Posted on Nov 09, 2008
2 Suggested Answers
SOURCE: doesn't print black ink
I have exactly the same problem...any solution yet...and yes the protective cover has been taken off.
Posted on Jun 07, 2010
Why does the black ink not print?
Try going to the maintenance screen and running the cleaner and any other adjustments that can be made from there.
Sep 28, 2014 | HP Photosmart 6520 e-All-in-One -...
My printer could not print out the Black words even though the Black Ink is full. How could i solve this problem ?
The problem is that the printhead of your printer or your cartridge is too clogged, try to open it up. If this does not manage to make it work, change the cartridge orprinthead
Apr 27, 2012 | Office Equipment & Supplies
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
DCP j125 Inkjet printer stopped printing showing msg. ink absorber is full. What to do?
well, cut the small piece of black tape (or you can use black permanent marker) and then cover the sensor of the cartridge, once the device will ask you to reinstall the cartridge and new system will detect as a new cartridge
Mar 30, 2011 | Brother DCP117 All-In-One InkJet Printer
My deskjet 3745 wii not print with new ink. The cartridge shows full and the printer goes thru all the motions. The final print is no color and light black
Use the HP software (installed when you installed the printer) to run a "print-head-cleaning" cycle -- you've got lots of ink, but the print-heads are CLOGGED.
Aug 24, 2010 | HP DeskJet 3745 Printer
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Mar 26, 2009 | HP Photosmart C7280 Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
131 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
