Question about Sub-Zero 690 Side by Side Refrigerator
Light working intermittently
When i open the door to the fridge portion the light sometimes does not come on for several seconds(>10) and sometimes won't come on at all. started doing this several weeks ago after the repair man changed our condensing unit.frige about 4.5 yrs old
  • Anonymous Dec 01, 2008
    we had a similar problem. It turned out to be the light switch that automatically turns one when the door is opened. It was getting stuck.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Go to Sub Zero.com and click the showroom locator on the top left of the screen. This will take you to a locator to find the authorized parts distributor for your area I believe the part number is 3060140 have themm check it using your model and serial number. . Once you have the part remove the three phillips head screws that hold the grill in place this is assuming you don't have the louvered grill. There is a grey power cord with a white quick connect seperate this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for your life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor.
Posted on Dec 03, 2008
Mine did the same. I jumpered the wires on the switch and it came on. The switch is bad. About $12
Posted on Nov 07, 2008
I HAVE THE SAME PROBLEM IF YOU GET IT RESOLVED PLEASE EMAIL ME.MSMCCREARY@COMCAST.NT
Posted on Nov 05, 2008
How do I deactivate the open door beeper?
You can try this special mode, but it will disable the interior lights as well.
You will be required to have both the fridge & freezer doors open, and to push and hold the compartment select MODE button on the display board for 10 seconds.
When the cabinet is in this special option mode the following will not operate:
  • The interior light will not turn on when the PC door is opened.
  • There will be no set temperature lights (LEDs) displayed on the display module.
  • The door alarm will be disconnected and will not sound even if the doors were to be left open.
NOTE: When in the special option mode, the fridge icon will be illuminated, indicating that the appliance is in this mode.
To cancel, you can exit this mode at anytime by pushing and holding the compartment select MODE button for 10 seconds. If not exited manually, the refrigerator will automatically exit this mode after 80 hours.
Oct 05, 2014 | Fisher and Paykel Refrigerators
Why is most everything freezing in my fridge. I have a fridgidaire elite.
Have you tried adjusting the thermostat level down several numbers to see if that solves the problem? It should be on the very top of the fridge portion when you open the door. Sometimes they are located in the freezer but most times the adjustment for fridge is in the fridge and freezer adjustment is in the freezer portion. If that does not work then you could be getting low on freon and it could be super cooling just before it runs out of freon. Try the adjustment first.
May 06, 2012 | Frigidaire Refrigerators
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
Jan 13, 2012 | Refrigerators
I own a KIC Fridge the problem is that the door does not closes the rubber does not grip tightly when closing. I have to sometimes lean on the fridge for 5-10 seconds for it to close and it sometimes does...
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
Feb 09, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
Jack at jackgreathouse@gmail.com The opener has an intermittent issue where when closing, the lights flash as if the sensors were obstructed. However, the sensors are aligned and both lighted and there...
There is only one thing that will cause the main light to flash 10 times and the door to reverse to the open position. It is the door sensors or the wiring to them. Sometimes the sensors are misaligned just enough that the light in the receiving sensor flickers ever so slightly and is very hard to see. This is an intermittent problem. Tweak them just a little and try.
Dec 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
1999 Dodge Grand Caravan - dome light intermittent
Could be a worn or defective door switch. That is the first thing I would check.
Oct 20, 2009 | Dodge Grand Caravan Cars & Trucks
Wire that connects thermostat to air diffuser assembly severed
Yes, the air diffuser has to open to allow the cold air from the freezer to be blown into the fridge.
Sep 21, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Kitchenaid KSCS25INSS
im not sure about the alarm but im going to assume its a door ajar alarm tilt the fridge back using the adjusters on the front wheels till you can open the doors about 1/4 let them go and it will close its self fridges are air tight and some times when you shut one door the air it pushes will slightly open the other the installation inst say level the unit but its better to have them leaned back the lights probably turn of auto if a door is ajar give that a try and let me know please
Feb 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
Sub-Zero 690 Side by Side Refrigerator Logo
150 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
