Question about HP P1130 21" CRT Monitor
Screen colour Hi The colour of my screen has shanged. It now had a green tint to it. I have tried all I can think off. What can you think off to help me?
    Problem Solver:
  • 6 Answers
Depending on how old your monitor is, it may be htat one of the color "guns" is going out.
Posted on Sep 24, 2006
SOURCE:
Green tint on TV screen when playing DVD's or Videos 2nd problem and can't record anything
1: Hi i would recommend trying the recorder on a different tv to check if the problem continues. If the green tint is gone then its the tvs inputs. If it is still green then its the player or the cord. Try a different cord if the green tint is still there then the player has a problem.
2: Now for the VHS to DVD. There are general a lock out encoded on the VHS if it is a store bought movie. This is to protect the content on the VHS from piracy and that would case the DVD to be blank. The VHS to DVD are made for converting your home videos like family vacations and stuff you record your self and not for commercial movies like the ones you bye at the store. If you want to convert old VHS movies to DVD you would have to get another VHS player and another device in between the VHS player and the VHS to DVD recorder.
Mar 19, 2014 | Televison & Video
My whole screen has a blueish green tint
  • Make sure the plugs are hard into the sockets, one loose pin can cause strange colour problems.
  • A faulty signal cable between PC and monitor can also cause colour problems, try a different cable if possible
  • Try it on a different computer to find out whether the computer or the monitor is the problem. If it's the monitor and none of the above works, it will need service or replacement. If it's the computer, your video card is likely to be the problem.
Apr 09, 2010 | Samsung Syncmaster 940BW LCD Monitor
The screen has a permenant green tinge which dominates all other colours. If watching football the grass insted of being bright grass colour green is more of a dull drab green
It could be the tint settings on your TV. Check your TV's settings menu for color/tint options. If you can't find it, break out the manual and look in the index for tint or color, then locate the page and it'll tell you how to get there.
Make sure the tint slider is in the middle, 0 or 50%, depending on your TV.
Best of luck.
Remember to rate my solutions! If you have time, drop a testimonial too - they really make my day. :)
Mar 29, 2010 | Sony BRAVIA KDL52XBR2 Television
New Bulb (30 hrs). Screen flickers after 10 minutes, color changes with green tint, then bulb shuts off.
Hi, I had a similar problem - the screen flicked through blue, green and red sometimes with a slight ticking noise. The problem seems to be that the colour-wheel is getting stuck - the first time this happened I sent it back to optoma who gave it a clean - it has happened again since thouegh and I just took the case off (you'll be able to see the colour wheel under a black plastic flap - remove the flap) I then used a cotton bud (q-tip) and turned the colour wheel whilst lightly pressing the cotton bud against the wheel - I also gave everything a blast with a can of air. My HD72i is ceiling mounted - optoma suggested putting the hoover pipe across the vents every now and then to keep the dust down. Essentially it's dust that is stopping the movement of the colour wheel.
Hope this helps.
Jonathan
Oct 21, 2009 | Optoma HD72 Multimedia Projector
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Packard Bell Easynote R1000 screen a tint of green
Hey Richard, Matthew here. This could be due to a wire being nipped at the hinge of the laptop. This is not and unusual problem and I believe should be fixed warrenty. Try emailing packard bell if the warrenty is still on it. If not any computer shop should be able to fix it for you. They should be able to quoat you on a price and fix it in about a day. Hope this helps. Good luck. Matthew
Dec 31, 2008 | Computers & Internet
Akai tv has failed to work
There are many circuit areas inside a TV set that can have burning components. Since you describe a colour change, I would think the fault may be in the video processor, screen biasing, or video drive path.
Jerry G.
May 22, 2008 | Akai PT4799HD Rear Projection Television
Icons green tint to them
I'm not sure but I think this model uses an integrated graphics card which would then involve replacing the entire motherboard.
It may be that the screen backlight is getting old - they often age by showing a tint, usually it is pink but I have seen them go greenish.
Try an external monitor connected to the laptop via the VGA d connector. If the picture on the external monitor has a good colour balance then it is probably not a faulty graphics chip, and likely to be the laptop screen.
Mar 16, 2008 | ASUS A6Km Notebook
Ds top screen half normal half green tint
i had the same problem  but it was blue tint shortly after the ds would turn on flash then turn off turned out to be the wire ribbon to top screen:: needed new top screen!!
Oct 22, 2007 | Nintendo DS Lite Console
HP P1130 21" CRT Monitor Logo
105 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
