When I sit down to the computer and open to anything on my desk top a small window, in fact 2 small windows automatically come up which I either have to cancel or click ok to get rid of them. No problems are apparent because I continue on with ease. However I am worried that there is a problem or one could develope. the first window says at the heading, D-link AirPlus Utility, the next box says AirPlus CFG.exe-Entry Point not found then.. it says the procedure entry point apssearchinterface sould not be located in the dynamic link library w/anapi.d11. Is there anyway to eliminate this? fix er Up?
  • siswoman Nov 02, 2008
    dear motor1258, I wanted to say when I rated your help that I would like to be able to come back and post again when I get it totally resolved. thanks so much
  • 6,674 Answers
You may have to reload your software for your d-link router, or call (1-877-453-5465 ) They are pretty good at helping with most issues that arise.
Posted on Nov 02, 2008
What cause my computer to shut down automatic and boot up again?
Overheating. Check the cooling fan and the heat sink fans for dust.
Feb 15, 2018 | Top Computers & Internet
How do i put gmail on desks top for quick sign in
1. Open a web browser (examples: Firefox, Internet Explorer). Be certain it is NOT maximized! (in other words, make sure you can still see an open spot on your desktop).
2. Click in the URL window, type "google", then press CTRL + ENTER.
3. (Notice the tiny lock icon in the left-most position of the URL window). Left-click on the lock icon & Hold the left-click mouse button down.
4. Drag & drop the link onto your desktop.
5. It will automatically be created and renamed to GMail.
note: this will work for creating any shortcut from a web address, not just GMail.
May 27, 2014 | Computers & Internet
Every time when computer restarts,i get new and fresh desk top, how can solve it ?
How do you shut down? With the windows start menu shut down process? Or push the on/off button on the computer? Take a look at this: http://www.winhelponline.com/blog/fix-desktop-icons-layout-not-saved-restart/
Jan 01, 2013 | Computers & Internet
Call display
The first step is to open the date and time dialog box located on the task bar on your computer.
Should be on the lower right side of the task bar.
Double click time or right click to open the dialog box.
The date and time box should open on the desk top.
Now click the Internet time tab.
Check the box that says automatically synchronize with an Internet time server.
Then you will see a list of servers.
Select a server from the drop down list.
Check apply and close the box.
Now every time you go on the Internet Windows will automatically set the computer clock to the right time.
Now, there is no need to worry about adjusting the computer clock again!
Hope this helps.
Nov 18, 2012 | Computers & Internet
Delete page superimposed on my desk top home page
I'm assuming this is a Finder window. In Finder, press Apple-option-W just before you shut down the computer. This will close all Finder windows; they will should not open when you start up the computer unless they were open when you shut it down.
If it's not a Finder window, you will have to deal with whatever application is being told to run at startup. Without knowing what it is, I don't have enough information to tell you more, other than to suggest you go to your User Accounts in System Preferences, click the Login Items tab and either check the Hide box for that application, or remove it from the Login Items list.
May 31, 2012 | Computers & Internet
My Maxtor 4 500 GB hard drive sounds like it's trying to run, but then it says that It's not connected to my computer. The little front light is lit up, but then it says it's not connected to my laptop. ...
This could be something as simple as the cable has gone bad. I would replace it first. If that does not work try this.
1.Right click the My Computer icon on desk top. If you do not have My Computer on the desk top it can be found in the Start Menu. It may just say Computer.
2.After right clicking it go to Properties in the drop down menu and left click it. You will get a window looking like this.
If you have Vista. I think Windows 7 is similar. Windows XP will be a window with tabs at top.
3.Open the Device Manager and you will get a window with a list of devices that are installed on you
PC. Looking like this.
In the list you should see your Maxtor it's probably down in the USB section. If you can't find it, it means you need to reinstall the drivers. If you do find it right click on it. You will have a drop down menu with different options on it. You can try uninstalling it reboot the PC and see if it auto finds it.
Hope this was helpful.
Good Luck
cookEmonster
Oct 13, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I JUST CONNECT A SECOND MONITOR TO MY EXISTING RADEON 7500. I ALREADY SETUP THE 2ND MONITOR ON THE DISPLAY PROPERTIES ( WINDOWS XP) I CAN SEE THE MOUSE MOVING FROM ONE MONITOR TO THE OTHER, DOES ANYBODY...
you'll have to drag them windowed to your 2nd monitor. Windows automatically will use your primary monitor unless you use software to control where which programs will load.
A good program to use is called Ultramon.
Sep 02, 2009 | Dell RADEON 7500 AGP Graphic Card
Bios setting problem
This happens because Windows is corrupted.
You need to start the computer with a windows install disk, or a factory recovery disk inside to reinstall the system.
Get a windows install disk and reinstall the system.
Nov 17, 2008 | Computers & Internet
Mac mini desk top can not click
You can access your desktop as though it were any other folder and thus delete its contents however you'd care to.
In Finder, go to the File Menu > New Finder Window. It should automatically open your user folder and show Application, Desktop, Documents, etc. From there, simply open the Desktop folder and delete the files.
If any other window is opened, click on Mac HD > Users > [your user name here] > Desktop and do the same.
Nov 10, 2008 | Apple Bundle Mac mini 1.66Ghz Intel Core...
Computers & Internet Logo
217 people viewed this question
David Payne
David Payne
