Question about Nintendo Wii Console
Wii video is black and white
I moved our wii from a LG Hi-Def TV to a Sanyo Plasma. It worked fine with the LG, but displays on in black and white with the Sanyo. I'm sure I've made an error in my hookup, but I've tried every combination and still get only black and white. Audio is fine. Any suggestions?
  • 4 more comments
  • Anonymous Dec 26, 2008
    I'm having the same problem. xbox works fine, unplug it and plug the Wii in and it is black and white.
  • allred123 Dec 31, 2008
    I am having the same problem. Wii works fine on reg. TV but when hooked up to a Samsung plasma it is black & white but has sound.
  • Anonymous Jan 31, 2009
    same problem. I just bought a new flat screen tv and it only plays in black and white
  • 9christina9 Feb 02, 2009
    i have the same problem
  • illusionist7 Feb 19, 2009
    moved wii from a regular tv to a sanyo flat screen and now it's black and white
  • julesdeans Mar 14, 2009
    plugged wii into my new lcd tv and all works ok but picture is black and white, all connections are correct.
Sometimes depending on the region of the game and whether your tv can play at either PAL or NTSC will determine if you can play on the game in colour. However if its Black and white at the wii home screen it maybe that your on the wrong setting e.g the Hertz your using.
Posted on Feb 03, 2009
Possibly you've plugged the video into the component (RGB) portion of the input - this calls for 3 connectors (Red, Blue, & Green) and if you only plug one in from a composite it comes out grayscale. If you only have one video lead (yellow connector) make sure it is going to a composite connection which should also be yellow. Otherwise, more info is needed about your connections.
Posted on Nov 03, 2008
Sanyo plasma hd tv 50 inch screen i am trying to hook up my granddaughters wii on our sanyo plasma hdtv cannot get it to show up in color on imput 2 or 3 video imputs. we have a dvd/vcr on video 1 imput...
Hi, take out the dvd player from port 1 and try the Wii in port 2 or 3 if the picture is good on the wii then you will need to get a 1 way scart lead for the DVD, not a fully populated one as these can cause interference between video inputs.
Hope this helps
Feb 11, 2011 | Sanyo Televison & Video
I just hooked my wii & all we get is black & white
I had the same problem. Instead of going directly into the TV, I tried plugging the component cable into the auxiliary jack in my digital cable box and that seemed to fix it. Works great now.
Jul 19, 2010 | Nintendo Wii Console
I bought a Nintendo Wii off of a guy and I didn't realize when I did that it came with Hi-Def RCAs. My TV only has a standard RCA hookup. I was told that I could still use the Hi-Def RCAs but what colors...
Those are not High Def RCAs.
The cables you received are called "component" when the picture is broken down to its component colors, red, green, and blue.
When compared to "composite" cables (RCA), the yellow is all the components in one, which is the video cable. The other red and white are audio.
Your component should be RGB, Red & White (audios)
What you need to do is buy a composite cable for the Wii, which shouldn't cost that much--usually under $10 bucks. Save the component cables for when you get a new TV since those are the more expensive of the two!
Feb 08, 2010 | Nintendo Wii Console
Wii - black and white
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
kibirag12
Jan 07, 2010 | Nintendo Wii Console
Tried to hook up to a AKAI Plasma TV...Only get black and white grainy picture
Ok this is a quick fix. All you ned to get a set of Wii HD cables from the store and all should be fine. Also you might not want to put your Wii on a Plasma TV its not good for the TV try using on LCD, LED, or plain old tv works best that way no image burn
Jan 03, 2010 | Nintendo Wii Console
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
I just bought a new plasma tv. I cannot seem to
You Plasma TV is probably an HDTV, which means you need to change the settings on your Wii to HD. Just go to the Wii menu and modify the TV settings. If you don't want to do that, make sure you connect your RCA cables to the non-HD slots on your TV so that the yellow RCA cable is in the yellow slot and not the green HD slot.
Dec 17, 2009 | Nintendo Wii Console
Hooked up cable box, wii box and dvd player to new lg 50 inch 720p plasma tv... all external components work, however, dvds and wii only show in black and white - no color...
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Dec 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Nintendo Wii Console Logo
847 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
