Question about Linksys Instant Wireless WMP11 802.11b
Wmp11 ver 2.7
I just purchased a new computor & had them install my wmp11 ver.2.7 in it. I have had this wireless card for just over a year and very satisfied with it so why get rid of it.
The new P4 with xp pro sp3 with IE 7.0 & my wireless card
With ethernet cord plugged in, all works great. I did update the driver I dn/lded from Linksys. My wireless says connected, strength excellent.
Status: limited or no connectivity
Packetts sent is only 63 with 0 received.
I am only about 10 feet away from my Linksys wireless router. Before with great results I was almost 100 feet away.
Where I purchased the computor says it is my equiptment problem, my dsl provider tech support says it isn;t their problem as all other computors i have work well, wireless and or connected by cord.
So here i am stuck in the middle, --=hmmm sounds like a
Could it be the sp3, the IE 7.0 or both? Or a compatibility problem with the new mother board?
I do hope someone has the answer & it be simple, if so thanks in advance.
  • 113 Answers
hi burby i think i can help u, its quite simple problem when confuguring the wireless if the wirelesskey is entered incorrect u will get limited or no connectivity delete the wireless profile and recreate it , will work
Posted on Nov 02, 2008
Will Wireless pci card pkw-wmp11-v27 driver windows 7 driver work for windows xp
The following link takes you to the wmp-11 page on the linksys website.
The User guide doesn't mention Win7 at all, but since this webpage has various links to details for your kit, I would suggest that rather than trying to use a Win7 driver with XP, download the proper XP driver from this site and use this. It'll probably save time and frustration!!!
Oct 02, 2014 | Computers & Internet
I have a Linksy WMP11 network card along with a DLink WBR 1310 router. Everything is installed fine along with drivers. My connection is showing excellent/strong/100% but i can't connect to Intern
Enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
Jan 25, 2013 | Linksys Instant Wireless WMP11 802.11b
I just put a Linksys WMP11V27 VER 2.7 Wireless B card in a Dell PC. I don't have the software to make it work...I can't find the right download on the linksys site. Can anyone give me a link? Thanks.
Hi Homeschoo308,
If you're looking for the driver for your WMP11V27 VER 2.7 you can download the driver here. Just click on the Downloads Tab. On the Drop Down select 2.7. Then click on Download.
Rate me if this helps so I can help others.
Thanks for using Fixya.
Feb 04, 2011 | Linksys Instant Wireless WMP11 802.11b
How do i make a password on my wifi router is linksys BEFW11S4 v.2
First, your router is old, go pickup a new one that supports the G standard, don't worry it will fall back to B standard or better yet get an N standard router. To setup wireless security directly connect a pc via cat5 data cable to one of the switch ports on the router (not the wan) and login to the web innerface, click the wireless tab, now look for the security or encrypted options. Most routers support WPA-2 encryption where you enter a phrase of 2 or 3 words if your router only supports web encryption go buy a new router. Save it, then go to your pc, disconnect, remove the wifi ssid from your managed wireless list refresh and search for the ssid of your wireless signal (name), now connect and the router should challenge you for your WPA pass phrase you setup in the router. Now your wifi ssid is secure and all connections will require the passphrase.
Aug 28, 2010 | Linksys BEFW11S4 802.11b Wireless...
Wireless will not connect to internet after installing XP Service Pack 3. Router is a Linksys WRT54G2, adapter is a Linksys WMP11. Router is set to "mixed".
Try upgrading the firmware for your routher and the linksys WMP11. Also try setting router to 802.11g instead of mixed to see if it connects.
Sep 29, 2009 | Linksys Instant Wireless WMP11 802.11b
Does router wrt160n have both 2.5GHz and 5GHz
Hello Bill,
The problem sounds like you have the router set to WPA security. The WMP11 cards do not support this security standard, they only use WEP 64 bit and 128bit. If you attach to the router with your vista machine and go into the configuration settings and change the security level to WEP you should be able to get online.
Jun 18, 2009 | Linksys Computers & Internet
Did you get my other reply?... about disabling you wireless care and har wiring your computer to YOUR linksys? I posted it this afternoon.
Mar 11, 2008 | Linksys BEFW11S4 802.11b Wireless...
Linksys Instant Wireless WMP11 802.11b Logo
261 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
