Question about Jura Capresso Impressa Z5 Espresso/Coffee Maker
No coffee will dispenses
It goes through the cycle but no coffee come out. It all ends up in the tray. As described, the coffee is ground and the machine seems to go through its usual cycles however the unused (dry) grounds are dropped into the grounds collector and the water into the bin. I have also tried using pre-ground coffee and have experienced the same results.
Jura customer service agents act bery surprised by this problem and suggest sliding the moveable coffee dispensing head up and down firmly to try to jog-free anything that may be clogging the system. After doing so, they suggest running through a manual rinse cycle to see if anything comes out of the heads. Typically there are some grounds that make their way through. Sometimes this technique works and more often it does not. I have now wasted enough coffee to try to find a sustainable solution.
  • Anonymous Jan 05, 2009
    I have the same problem after brewing only 20 cups of expresso and this is a new machine!!!!
  • Anonymous May 24, 2009
    I was wondering if you have solved your problem? As we have now the
    same problem, coffee not coming out and going into the tray, also the rinse water. We had our coffee machine for 5 years and this is the first time this is happening.
    Please let me know if you know how to resolve the problem. Thanks
What oilerfan said. I had the same problem, when I called their very helpful customer service, I was given the same directions.
Take out the tray.
Inside the machine you can now see a flap hanging from the top.
Reach behind the flap, and you should feel a round object/filter. It has a little dimple sticking out in the middle.
Wipe the filter with a paper towel.
Put the machine back together, and voila you got your coffee brewing again.
Posted on Jul 07, 2009
  • dgodsiff Aug 26, 2010
    Run a decalcify cycle
  • 3 Answers
How fine have you got you grind setting, if it is a new machine it needs to be on course Grind, fine grinds clog the filter.  You need to reach into where the tray goes with a cloth and wipe clean the filter bin which is right behind a flap
Posted on Dec 09, 2008
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: no coffee will dispenses
I would remove the coffee spout and check the lines into it. The coffee seems to stop when it hits the spout and goes through the by pass instead. Remove the spout(be careful) then run a coffee and see if it works.
Posted on May 24, 2009
I have a saeco super automatica Leaking water
Take the brew unit out when the machine is off and cold. With your finger, check the well next to the large gear on the inside of the machine. This is the gear that fits in the back of the brew unit when it is in place. That well may be clogged with fine coffee grounds and some mildew build up. You might notice that after brewing, very little water will has been flowing into the drip tray. Take a Q-tip and push it through the hole at the bottom of the well to remove the coffee ground buildup. The excess water after brewing will flow through normally now and not behind the brew unit.
Mar 02, 2017 | Saeco Coffee Makers & Espresso Machines
I cannot get the drawer to close completely on my Jura E8 in order for the "missing drawer" light to go off. I've unplugged the unit to allow chip to reset... nothing. I think the elevator is...
I have the same machine and this seems to happen if the grounds bin is pulled out before it goes through a full cycle. take both the grounds and water trays out. Try to fit the grounds bin around the "elevator", slide the grounds tray underneath that then the water tray as well. It should slide right in then the machine will complete the cycle and work just fine :)
Feb 06, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
May 24, 2009 | Jura Capresso Impressa E75 Espresso &...
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Cleaning machine propt will not go away
I have the same machine and had the same issue all day yesterday. Tech support will tell you to clean the tamper (round disk behind the tan/gray "flap"), which you should do. That didn't do it for me, however, so I kept cleaning. I cleaned out the chute where coffee powder goes. Then, after turning off the machine and removing the tray, I used my fingers to go up/under/behind as much as I could get to. I found the motherload of old coffee grounds. It's hard to describe where, but it was all around that metal area in the center. Just keep poking, but use your fingers so you can feel where the coffee is. I tried q-tips, but that didn't work..you have to feel it. After I got all the gunk out, I ran a cleaning again - no tablet - and it no longer said "press rinse" at the end of the cycle. It asked me to dump the tray, and then it went to "ready"! Yahoo - saved a bundle in shipping and repair.
Sep 27, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Leaking water and coffee grounds behind and below drip tray at end of brew cycle
If you take off the top and start your machine you will see and hear if the boiler leak, try this first to work around your problem.
Let me know if i can help you more.
Best regards
/Mirran
Sep 08, 2008 | Saeco Vienna De Luxe Espresso Machine
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Cannot properly align Saeco Italia Coffee Dispenser
new to you what make that turn is 2 plastic gear inside maybe gear are loose and jump maybe that why it doent aling to check that out you need to open like everything a big job but if you whant a saeco coffee and belive me it worth it cheers
Jan 22, 2008 | Coffee Makers & Espresso Machines
Hi, We had a similar problem and it turns out the beans we were using were too oily and clogging up the works. We solved it by using a slightly more coarse grind (and brewing a stronger cup), and by buying only the best beans (oily beans don't make coffee stronger, just means they aren't good beans and by roasting longer can make the coffee taste stronger). Try Barefoot Coffee Roasters (I don't work for them, just love their coffee). We also use the cleaning tablet more often than prompted, and clean the inside of the flap when we dump the grinds. Good luck. Great coffee, but finicky machine!
Dec 13, 2007 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
795 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
