Question about Pentair 2" Pvc, 3 Way Lube Free Diverter Valve, with 2.5" Slip Outside
Operation my Pentair 2" Pvc, 3 Way Lube Free Diverter
Should the off tab on the pentair 2" pvc, 3 way, lube free diverter valve be "up", to the "left" or to the "right" in order to heat the pool? (sorry for the question but my first pool...lol.)
  • jesterdan Nov 14, 2008
    I have the same problem when I try o divert the water to cerculate just in the spa it drains is the th problem you have if so im looking into it today ill let you know if i fix it
  • 22 Answers
Every valve is unique to the system in which it is plumbed. You cannot specifically say that there is one way to turn a valve and then apply it to your situation. So, there is a way to determine what you need. Three way valves should be plumbed with the water flowing into the valve at what one would recognize as the "leg" of a letter "T".
Assuming the valve is plumbed this way, the source of flow to the other ports is either from the pool/spa or to the pool/spa. for a valve plumbed in front of a pump, the direction is from the pool/spa. For the other 3 way valve, it is to the pool/spa.
The easiest way to detemrine flow is point the valve handle to one direction. Keep in mind that water flow travels under the valve handle. So, if you see water flowing from your skimmer at the pool, the direction the valve handle is pointing is FROM the pool. The opposite port of the valve (180 degrees) is FROM the spa. Do the same for the other valve. If water flows to the spa with a jet action as opposed to a small trickle, you have directed flow TO the spa.
In general, both handles will be pointed in the same direction. At times, they may not so that is why you need to determine flow and then label thew ports.
It is not wise to run a system with the flow not set for POOL suction/POOL return or SPA suction/SPA return. Having the valves in opposite direction can result in an elevated spa draining to a level equal to the pool.
Posted on Dec 21, 2008
Where to find PVC valve on 460 engine
PCV valve will be located either in valve cover (tappet) or cover over the lifters under the intake. Not real sure as I haven't touched a 460 in 20+ years but know that it has to be able to get vacuum from the intake system and have access to the inside of the engine above the oil liquid level. Should have a thumb thick (1/2 - 3/4 inch) hose going to it from the intake or carb.
This has nothing to do with a 2 inch pool diverter valve......
Sep 30, 2012 | Pentair 263029 2-Way, 2-Inch PVC Pool...
Suspected air leak from pentair 3 port valve?
One way to test this is to pour cool aid on the valves with it set to both settings and see if the water effluent changes color. If it does then you are looking at a rebuild or new valve. If it does not then you need to check the line to the skimmers.
Aug 10, 2012 | Pentair 2" Pvc, 3 Way Lube Free Diverter...
How do I remove a Pentair 2'' slide valve, it doesn't pull up out of its position after removing the top holding bracket, seems to be stuck and I don't want to force it for fear of breaking the mechanism.
Thank you for posting your question here on Fixya.com.
Keep trying. The o-ring(s) are probably rolled up and you need to force it out. I have never broken the body after yanking several of those out so I doubt you will break the valve. If you do it can be replaced without getting a whole new filter...just in case.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jul 31, 2010 | Pentair 2" Pvc, 3 Way Lube Free Diverter...
Can these valves leak and cause a pump to lose prime
Absolutely...There are 'o' rings they may be leaking on the stem of the handle
Jan 09, 2010 | Pentair 2" Pvc, 3 Way Lube Free Diverter...
Which positions of the handle divert waater
The 'stop' is opposite the direction the handle extension points, so in the picture shown with this post the port pointing left is closed and the ports facing down and right are open.
Jul 31, 2009 | Pentair 2" Pvc, 3 Way Lube Free Diverter...
Where is the pvc valve located on a ford exployer 4.0 liter engine.
the pcv valve is located between the intake manifold and the firewall on the drivers side, you may have to remove the throttle body cover to access it, it's not easy to get to.
Jul 09, 2009 | Pentair 2" Pvc, 2 Way Lube Free Diverter...
Does anyone know if Pentair makes a 3 or 4 inch PVC, 3-way lube-free Diverter Valve?
Not in the residential products. IF they do, it would be in a commercial use, but I believe they do not.
Mar 17, 2009 | Pentair 2" Pvc, 3 Way Lube Free Diverter...
Pentair 2" Pvc, 3 Way Lube Free Diverter Valve, with 2.5" Slip Outside Logo
601 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
