Question about Honeywell Heating & Cooling
Controller for heating system system is showing "EEE". Controller is a Honeywell 32207501-002 rev b
5 Suggested Answers
  • 15 Answers
SOURCE: I have a Vulcan/ILEC ducted
there is probably a sensor in the duct somewhere that is either fault or maybe quite dusty. be careful though it may have mains voltage at the terminals
Posted on Jul 10, 2008
rylee_smith
  • 8619 Answers
SOURCE: My Honeywell EMM-3 zone controller
Hi
Thanks for using FixYa. Perofrm this test--
Connect DATS Sensor to EMM-3 (optional).
a. Reconnect power to EMM-3.
b. If system is in Purge mode, press PURGE OVERRIDE on EMM3.
c. Verify SYSTEM LED is no longer flashing. This confirms proper DATS operation. (Flashing occurs in Idle and Fan modes only.)
Also see page# 9 & 10 from this link--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 28, 2009
  • 415 Answers
SOURCE: Upgrade Baystat 239 to a Honeywell RTH7600D controller
For Trane sytems, B is your "Common" wire. O is your reversing valve relay, G is your fan, Y is your compressor contactor, R is Hot, Brown will not be used on your electronic tstat. X2 is your backup electric heaters. Without knowing what terminals are on your new tstat, I cannot offer more information than this. The installation manual may indicate what each terminal is controlling. I strongly suggest to write down ALL of the terminals and colors from your old t-stat and be sure to turn off the power to your air handler. Put the fan switch on your tstat to ON before turning off the power. Make sure the fan is running. Then turn the power off to your Air Handler. If your fan stops running, you have turned the power off to your tstat and are ready to start replacing it with your new tstat. I hope you find this helpful. Good Luck!!!
Posted on Feb 07, 2010
SOURCE: Honeywell 32207501-002 air conditioner won't come on
The # is on the BACK- yeah go figure, of the unit. Lift the front up from the bottom and it will come off (it goes back on). THEN you will see your number. Mine was a CT3611.
Posted on Apr 07, 2010
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
How does one wire a 24 volt White-Rogers evaporative cooler controller replacement for an ancient mercury switched Honeywell controller?
Red wire, R with a jumper to RH
White , W
Green, G
Yellow, Y
Make certain you understand thermostats come setup for gas, so pay attention to what your heat/cool unit is, that's very important, also make sure to shut off the power to your system before removing the thermostat.
Jul 08, 2014 | Honeywell Heating & Cooling
EEE message on my control panel
Power Reset at mains. You had a power 'glitch' and it locked the controller into error mode. Shut unit off for 5 minutes, unplug, then plug back in and see if it resets itself.
Apr 14, 2014 | Honeywell Heating & Cooling
Display panel shows 6522 Rev HH
check wiring to controller either wires touching at plugs or wires cut
Sep 11, 2012 | Jandy Aqualink Rs4 One Touch Control...
Honeywell smartfit controller not adjustable
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 10, 2010 | Honeywell Heating & Cooling
User guide needed for old Honeywell programmable heating control
It depends on your system some will only work with hot water on and heating do you have two zone valves?
Jul 18, 2017 | Honeywell TH4210D1005 Heater
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
My central heating system comprises a worcester bosch system boiler and honeywell smartfit controls. The problem I am having is that the central heating doesn't seem to knock off at the preset temperature...
You could possibly have an ignition problem. The controller will go into a lock-out condition if flame is not established. Turning the temperature control down and then back up may be serving to reset the control system so it tries again.
May 21, 2008 | Honeywell Heating & Cooling
Driver for rtl 8139D
maybe you got the wrong version of your driver, realtek got an A&B device driver..
Feb 15, 2008 | Computers & Internet
Heating & Cooling Logo
105 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
