Question about Fahrenheat PHH15002 Oil Filled Baseboard Heater
Fahrenheat baseboard heater leaking oil
Why and what can I do?
Buffalo12980
  • 625 Answers
SOURCE: basboard heater installation
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
Posted on Nov 04, 2007
hotuna
  • 288 Answers
SOURCE: Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Posted on Jan 09, 2008
Buffalo12980
  • 625 Answers
SOURCE: Fahrenheat baseboard heater knobs
go to a radio shack to find replacement knobs. get something called a "bar knob." this has a set screw which holds the knob on the thermo shaft. use a marker and print lo med high and off on the unit or use a brother p touch label maker.
Posted on Jan 10, 2008
SOURCE: Fahrenheat F25408 Electric Baseboard Heater noise
how to wire this unit
Posted on May 31, 2008
SOURCE: Fahrenheat electric baseboard heaters are not safe for children
A few companies sell child-proof covers that prevent little fingers and small objects from getting into the radiators. Try searching Child-safe baseboard heater covers in a google search or PexSupply.com.... we use them in daycare centers.
Posted on Jan 30, 2009
What is the "oil like" smell in baseboard electric units? Do they use an oil in the assembling? Thank You
Hello KUNNES The smell should dissipate after the 1st couple of uses.They probbaly use some oil/protectant during assy.There should NEVER be any smoke.
Aug 18, 2010 | Fahrenheat Electric Hydronic Baseboard...
IS A HYDRONIC ELECTRIC BASEBOARD MORE EFFICENT THEN THE STANDARD ELECTRIC BASEBOARD HEATER
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
How to wire unit baseboard heater to the power to thermoster
That is a portable unit and should not be hard-wired and controlled by a wall-mounted thermostat. The unit may never cut off that way.
It is considered a "space heater" not an area heater.
===sorry===
Sep 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Jan 29, 2009 | Fahrenheat FBE15002 Baseboard Heater
Parts for Fahrenheat lfp6152e
Contact supplier Marley @ 1-800-642-4328
Dec 29, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
no this is normal for this type of heater during its run time,I hope this makes you feek a little better!
Oct 24, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Baseboard heaters
measure each room you want to heat. multiply the length x width, this will give you the square footage of the room to be heated, multiply that by 10 and that is the number of watts needed to heat the room using 220/240v baseboards.
Sep 11, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
Fahrenheat PHH15002 Oil Filled Baseboard Heater Logo
93 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
