Question about Sanyo PLC XF45 Multimedia Projector
Temp warning i have a sanyo plc-xf-45.........i have a lamp replace light indicator......also when i turn it on tempwarning mlight flashes and turns off.......any idea what the issue is?
  • 115 Answers
Clear the air flow and replace or clean air filters. that will solve.
Posted on Jan 06, 2009
  • wiqk Jan 01, 2011
    nothing happen,.we clean already all the filter but still warning temp comes out when you turn it on..
  • lukastm
    lukastm Oct 29, 2012
    how do I stop the air flow??
Hi, There was a popping sound from my PLC-XL50, then the projector turned itself off. I noticed that rather the replace lamp light being lit, the warning light is on. Does this mean the lamp has died...
This is an indicator stating the lamp is bad and cannot power the projectors backlight. You should replace this prior to any additional powering of the unit.
Sep 22, 2011 | Sanyo PLC-XL50 Projector
My sanyo PLC-sw20a lamp does not light after turning on, the red lamp indicator still lighted and there is no indication for lamp replacement. Is the lamp busted?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 20, 2011 | Sanyo PLC-SW20A Lamp
I have a model PLC-XT11 and when I turn the power on the temp light and green ready light begin to flash. The red lamp light is on steady. I replace the lamp but no luck.
one or more of the fans may not be working right. also, the temp sensor may be shot. if the last time you used it it wasn't shut down properly, it may still be in cool-down mode.
Nov 06, 2009 | Sanyo PLC-XT11 Multimedia Projector
Can't get the lamp light to turn off on my sanyo xp57 projector. replaced the lamp and the lamp warning light won't shut off.
Go into the menu and look for the settings icon. Under the setting icon you should see a lamp counter reset button. Select that and the lamp replacement light will go out.
Jul 30, 2009 | Sanyo PLC-XP57L LCD Projector
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Sanyo plc se15 no light output
i all,hoping you can help with my problem.Ihave been given a sanyo plc se15 projectoe but with no lamp originally,the "lamp"indicator and "lamp replace indicator"were originally lit but when i have installed a new(23hrs use previously) lamp i have no light output and these 2 indicators are still lit! what voltage should i have on the lamp terminals(i a fully qualified electrician btw) is there some sort of reset procedure as i dont have any instructions etc
thanks in advance for any help
Mar 05, 2008 | Sanyo PLC-SW30 Multimedia Projector
How to check lamp hours on xf-45 or xf-35?
On the XF-45, you push the "UP" button and then the "Menu" button and hold both of them for approximately 20 seconds. After that you will see a bunch of numbers in the top left hand corner of the screen. Using the Left and Right arrow keys, move the "Group" number until it reads 111. Then using the Up and Down arrow keys to scroll through each lamp (0-3).
If you move the "Group" number to 110, you can see total number of hours that socket has run.
Jan 22, 2008 | Sanyo PLC XF45 Multimedia Projector
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XF45 Multimedia Projector Logo
503 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
