Question about Samsung U900 Soul Cellular Phone
Adding music as a ringtone
I have music on my phone i want to use as a ringtone. I only seem to be able to do this by adding to individual names when i want to add to all contacts.
can anyone help
  • chris_harrag Nov 02, 2008
    strugglung with same problem...
  • philipvectra Mar 20, 2009
    can not add my music as a ring tone
  • 3 Answers
Call samsung 1-800-726-7864
Posted on Nov 02, 2008
Set ring tones to each contact
You should have that option when adding or editing a contact. The other alternative would be when choosing a ringtone some phones will ask if it's for a group, a contact or a general use ringtone. It depends on the phone.
Mar 04, 2015 | Cell Phones
I can't set a mp3 ringtone to my Htc 7 mozart
Well, after you have made a ringtone of you own, now, it's time to add custom ringtone on HTC 7...
Method 1: Set Ringtone on HTC 7
Choose the ringtone that you made yourself from music files, adding them to ringtones Settings.
Method 2: Set Ringtone on HTC 7
This method can help you choose the ringtone that default in HTC 7
Step 1: Tap on START
Step 2: Tap All apps
Step 3: Tap Settings
Step 4: Tap Ringtones & sounds
Step 5: Tap Ringtone and select the ringtone of your choice.
Dec 31, 2010 | HTC 7 Mozart Cell Phone
I want to download an app to download songs and ringtones
Method 1:
Transfer the song(s) you want to set as ringtones onto the microSD card either by connecting to pc via USB or using an SD adapter. Next, Tap on the Music Player, open the music list, press the menu button and select PLAY ALL, this will scan your SD card for music/audio files. Once all your songs have been added to the list, select the song you want to set as ringtone and click MENU key, choose SET AS RINGTONE and that will take you to the RIngtone Trimmer, make the ringtone 30 seconds or less, select Trim and you're done.
Method 2:
Root your HTC Hero, create a directory in your C: drive and name it HeroRIngtones, HTC, or whatever and put there all the ringtones you want to be added (30 seconds or less), then open Command Prompt; make sure your device is connected and already visible. Run the following command "adb push directoryname/myringtone.mp3 /system/media/audio/ringtones" and press enter. Do same procedure for all the audio files you want to set as ringtones.
Method 2 is not available for non-root users.
Dec 17, 2010 | HTC Hero Smartphone
I want to put a music tone as my message tone and i dont no how to get the music to become my message tone 4 an LG arena
Well first you have to add music on your phone by addin music into the sounds folder in mass storage then you go to profile in phone settings then selecct a profile n it will give u the menu
Feb 26, 2010 | LG KM900 Arena Cell Phone
I am adding music on SD card, by a Mac, but when put card into ph, it does not transfer to "My Music", it transfer to audio/ringtones
make sure you read the manual about your phone to see which music file format does it support(MP3, WMA etc).
May 31, 2009 | LG Vu CU920 Cellular Phone
Unable to upload my own ringtones from my computer
If you have the music on your computer you can send it in a message to the phone and then open the message and apply it as "use as ring tone". Or if you have an old phone that allows you to down load it to the phone directly, then you can send it from that phone in a message to the other phone, open and apply as "ring tone".
Mar 12, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
Samsung SHC-U740 Alias resets itself when adding songs to library
just format the memory card and put songs again on memory card. format with fat format not fat 32.
Jan 01, 2009 | Verizon Communications Samsung Alias Cell...
Copying music from 'my music' onto LG KU990 VIEWTY
dear,
i think you are copying just list not the songs.so u have to save the songs individually to phone where they are lying and  then go to media player that u have installed in phone (if u have) and put it on list.
regards,
Jan 01, 2009 | LG KU990 Viewty
Setting ringtone
Here are instructions for setting the ringtone on a Palm Treo 750 running Windows Mobil 6.0 Professional
To change the ringtone do the following:
1.Go to Start and select Settings
2.Select "Sounds and Notifications"
3.Go to the "Notifications" tab listed along the bottom
4.In the Event field either press the middle button or use your stylus to see the drop down menu.
5.From the menu choose whichever option you want to set the ringtone for. i.e. Phone:Known Caller or Phone: Unknown Caller
6. Once you have made your choice go to Ring Type. Here you want to access the drop down menu so you can chose how long the ringtone will sound.
7. Once you have made your choice go to Ring Tone. Access the drop down menu again to cycle through the different types of ringtones. If you have music on your phone you can also choose this as your ringtone instead of having to purchase them but first some steps have to be taken in order for the music to be seen in the drop down menu. I will put that at the bottom of this solution just in case it's needed.
You can use this method to set ringtones for other things such as incoming email, messages and reminders. With Messages Emails, and reminders you can also select music that is already on your phone but I have not been able to do the same with smaller things like "Connection Disconnected".
Here are instructions for making music on your phone into a ringtone.
You may want to have an expansion card for this but it can be done without one. If you are not using an expansion card and would like to make all of the songs on your unit into a ringtone you may have to delete the music files after adding them to your ringtones.
In order to make your music available for choice in ringtone all songs must be in the "My Music" Folder prior to beginning.
Begin by following steps 1. and 2. from above then:
3.Select the "Manage" tab
4.Select Menu then select Add
5. For this part I find using the stylus is simplest. On the top left of the screen push the down arrow found under the words "Select a Sound"
6.From this drop down menu select "My Device" then click on the "Music" Folder
7.Once there Highlight the song you would like to be a ringtone then click "Select"
All done Now the music on you phone is a ringtone. Ringtones made this way can be deleted anytime simply by going into the "Manage" tab again, highlighting the song you wish to delete, Selecting "Menu", Then selecting "Delete"
Nov 22, 2007 | Palm Treo 750v Smartphone
Individual caller ringtone
1. go to contact list and edit contact then select assign tone and select tone according to ur choice, but take care of selected profile.
Aug 17, 2007 | Nokia 6233 Cellular Phone
Samsung U900 Soul Cellular Phone Logo
78 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
