Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
Will not drain and shows E6 error code
Dishwasher stops every ten or fifteen minutes and shows error 6. I keep restarting it to get through the programm. I keep cleaning out the filter to make sure there is no blockage. I have also tried pulling the dishwasher out from the wall to see if the drain hoses are getting kinked - but to no avail.
I had this problem and eventually found a small piece of mussel shell in the bottom part of the machine, it seems they are very sensitive to the tiniest fragment of debris.
Posted on Jul 14, 2007
SOURCE:
Daewoo front load error code E6
daewoo washing machine error code e6
Feb 11, 2018 | Daewoo Washing Machines
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
E6 error code on fisher & pykel single door dishwasher
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
LG Control Panel Overview
www.lg.com > ... > Repair > Locate Repair Provider
LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
Nov 19, 2015 | Fisher and Paykel Dishwashers
I20 trouble light on fridigaie dishwasher
Try this
"Based off the information you have provided your Frigidaire dishwasher is showing you an "I20" error code. I have located that code and it is described as a drain problem that could be either your pump or control panel. I would recommend resetting you appliance, which can be done by flipping the household circuit breaker off for roughly ten minutes. If you continue to experience the error code I would seek assistance from a professional to come diagnose and repair your appliance"
Aug 13, 2015 | Dishwashers
Frigidaire dishwasher Model #fghd2433kf1 flashing light with Error 'S'. Dishwasher will not start. I was able to restart it last time this happen by disconnecting power and then pres
Thank you for your post, Cathie Sanchez!
I understand that your Frigidaire dishwasher is displaying error code "S" and will not restart. The error code "S" usually stands for sanitize, this could also be a miscommunication within the control panel. I would recommend performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for roughly ten minutes. If you continue to experience issues with the error code I would suggest having a professional technician out for proper diagnosis and repair. Hope this is helpful. -Matt
Jan 07, 2015 | Frigidaire Dishwashers
I get an Er code 5 on our Dishwasher and it keep restarting in the rinse mode
Thank you for your post, friend!
I see you are having trouble with your Frigidaire dishwasher and you are receiving error code "5". However, it appears "5" is an invalid error code. May I have you model number please? Typically you can locate your serial tag on the inside wall on the left hand side. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your dishwasher. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 18, 2014 | Frigidaire Dishwashers
Dishwasher error code P0
Hello Alan Gibson - Are you certain the error code is P0? This manufacturer does not have an error code P0 for any dishwasher or other units. Could you please try reprogramming the unit by flipping the household circuit breaker off or unplugging it? Wait approximately ten minutes and restart dishwasher. If the unit is experiencing a generic communication error, it should be follow by another fault code. What is the error code? If it continues to display P0 then consult a professional to move forward accurately.
Feb 05, 2013 | Electrolux EWDW6505GS Fully Integrated...
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
1,195 people viewed this question
Top Smeg Dishwashers Experts
Marvin
Marvin
Norman Al-Anbar
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
