Question about Sanyo DVW-6000 DVD Player/VCR
How to set the time
Can't change time
I have a Sanyo DVW-7100 Combo DVD & 4 Head VCR, I cannot change the time. Can you help me?
Lori B.
Posted on Mar 04, 2009
Have you tried using the set up menu button on your remote? nanafromlv
Posted on Jan 21, 2009
Change the date and time
Good day!
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
Mar 28, 2014 | Computers & Internet
Clock changes time
The BIOS battery keeps the Date & Time and the BIOS settings from changing. If the BIOS battery is flat then these settings are changed to the factory settings.
Yuo need to insert a new BIOS battery then go into the BIOS setting to set the Date & Time etc.
Sep 16, 2012 | Computers & Internet
How do i change the time on the clock?
Hi the details are below. Hope it helps I have added a link for the manual at the very bottom, Good luck with it.....
Time Adjusts the systems clock. The time difference (+, -) between the time originally set in your navigation system is set here. You can also select summer time On/Off. > Time settings, (See page 131) Summer Time Choose whether or not to take summer time into account. On: Summer time is taken into account. Off* Summer time is not taken into account...... When the period of summer time comes, or when the summer time ends, your navigation system does not automatically change the summer time setting. > Change the summer time setting, (see Page 131)
To set the time difference, touch "+" or ."-" The time difference between the time originally set in the navigation system (Pacific Standard Time) and the current location of your vehicle is shown. If necessary, adjust the time difference. Touching "+" or "-" changes the time difference display in one-hour increments. The time difference can be set from +3 to -3 hours. If necessary, set to summer time. Daylight Saving Time (DST) is off by default. Touch "Off" to change the time if you are in the daylight saving period. This turns the display below summer time "On". 9 To complete the setting, touch "Back". The map of your surroundings appears. This completes the setup of your navigation system. Chapter 1 explains the basic operation of your navigation system. > To change the time later, (see page 75)
The link to manual here:- http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/417273154AVICD3OperationManual0221.pdf
Mar 29, 2011 | Pioneer AVIC-D3 Car DVD Player
How do I change the time on the clock?
  1. Tap Menu > Settings > Phone
  2. Tap Time & Date.
  3. Tap Time Format, Date Format or Auto Update > Save
It's best to keep it set to Auto Update so that it takes the network time and updates for DST changes.
Hope this helps. If so, please consider rating this solution.
-best regards,
M
Mar 14, 2011 | Pantech Pursuit P9020
How do you set the clock for manual clock in?
From the manual:
Press the SELECT button and position the cursor at the "TIME". At that moment, the "Hour" flashes. (The flashing means it can be changed.)
Change the "Hour". Press the CHANGE button to set the desired hour. Press the SET button. At that moment, the flashing changes from "Hour" to "Minute"
Change the "Minute". Press the CHANGE button to set the minute. and then press the SET button. At that moment, the "Second" starts to run from "00".
After you finish setting the time, press the SET button once again. Now the time setting has been completed.
Setting the Date
Press the SELECT button and position the cursor mark at the "DATE". At that moment, the "Year" flashes. (The flashing means it can be changed.) Change the "Year". Press the CHANGE button to set the year. Press the "Set" button. At that moment, the flashing changes from "Year" to "Month". Change the "Month". Press the CHANGE button to set the month. Press the "Set" button. At that moment, the flashing changes from "Month" to "Date". Change the "Date". Press the CHANGE button to set the date, and then press the SET button. After you finish setting the date, press the SET button once again. Now the date setting has been completed. Replace the cover.
Feb 28, 2011 | Lathem Time 900E Electronic Recorder,...
I need to reprogram my 5655 so that the correct date and time is announced by the system
The time and date is set at the base unit.
Press the TIME/SET button
Press the TIME/SET button again
Press the CHANGE button until the correct day is announced
Press the CHANGE button until the correct hour is announced
Press the CHANGE button until the correct minute is announced
Press the CHANGE button until the correct year is announced
Press the TIME/SET button to finish and the current clock setting will be announced
You can hold the CHANGE button down when setting the minutes or year to increment in steps of 10. Following is a link where you can download the manual.
http://att.vtp-media.com/ecp/documents/product_Product/614/UserManual/2041/e5655_manual_bkm.pdf
Feb 25, 2011 | AT&T 5655 Cordless Phone
HOW DO YOU SET THE DATE AND TIME?
It should be in 'settings' on your cell phone menu. Search around your phone. It could also be in 'organizer'. On my old one, it was in 'organizer', and once I went there, there was a 'set date and time' button. Here is the answer from the Vtech website: "Make sure the answering system is on. Press [Time/Set]. The system will announce the current clock setting, then announce "to set date and time, Press Time/Set". Press [Time/Set]. Press [Change] until the system announces the correct day, then press [Time/Set]. Press [Change] until the system announces the correct hour, then press [Time/Set]. Press [Change] until lthe system announces the correct minutes, then press [Time/set]. The system announces the current clock setting. Note: You can press and hold [Change] to advance the mninutes in increments of ten. "
Jun 06, 2009 | Vtech Lands Phones
How to change time in Tomtom GPS device
Here's the solution to your problem:
> Tap the "Change preferences" icon
> Tap the Arrow Icon until you reach the screen with the "Set Clock" Icon
> Tap how you would like the time displayed
> Tap done
> Set the correct time to display
> Tap Done
This will set the new time on your unit.
Mar 13, 2008 | Tomtom ONE GPS Receiver
Resetting clock
Press the SET button until you cycle through the alarms and the Colons on the time start to flash. use the right and left arrows from the CD buttons to adjust time; After time is set; press the SET button. Be careful to not fat finger and hit the CD button when pressing the SET buttons. That will turn on the AWFUL NAP timer. That's another headache.
. Stop the Nap alarm Press NAP to start NAP flashing. Press and hold NAP to cancel the nap setting. If this does not work; try again. It seems to take me a time or 2 to get it to work.
Feb 04, 2008 | GE 74801 Clock Radio
I do not know how to set my clock on my razr after the time change last nite
Settings
Initial Setup
Time and date
  • Turn AutoUpdate Off
select and make the change
Nov 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Sanyo DVW-6000 DVD Player/VCR Logo
154 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
