Question about Philips 55PP9352 55" Projection Television
Phillips 55pp93 5217 - starts up and then shuts down
I have a phillips 55pp93 5217. It powers on for a bout 20 - 30 seconds. I hear the tubes warm up (sometimes start to see a faint picture and then
the shuts down. I know that most modern TV's have auto protection that
will shtu them down if ceratin components fail but how do I figure out if it's just a matter of replacing the RGB tubes etc.
Any help wouild be most appreciated !!!
  • 2 more comments
  • conod Nov 02, 2008
    It was off all night then I turned it on and it would not start.
    Is there somewhere I can get a layout/schematic for this TV?
    Still not working I will test the vertical deflection Ic if i can get a schematic.
    However I could see at least a faint outline of the picture in the first attempts to get it running and the picture looked correct, could not determince color though.
    I'll look at the PS first...
  • 535 Answers
Chak the power capacitor its has been likey or damged
Posted on Nov 02, 2008
    Brigadier General:
  • 6,966 Answers
Initially, pls do a run down of past events:
  • was there anything out of the ordinary, ozone smell, power outages/interruptions, improper picture display;
  • any instance where the unit failed to turn on at the first instance.
In the unit's current state:
  • any blinking lights, if yes how many, any sequence;
  • any other indicator, clicking sounds;
  • is the outlet supplying sufficient power, have you tried it in another outlet;
  • are you using a power strip;
  • have you tried powering the TV through the front panel controls.
Other than the reset, all other diagnosis/checks would require opening the unit. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 02, 2008
    For the schematic diagram and/or service manual, pls confirm the Chassis Number DPTV310.
  • Louie  Role
    Hi again,
    You may want to check out this Service Manual that covers the DPTV305 DPTV310 DPTV315 DPTV330 DPTV335 DPTV340 DPTV345 51MP392H-17 CHASSIS
  • 89 Answers
Please check the ic of vertical deflection circuit first
  • Philips Master
  • 19,396 Answers
TRY FIRST UNPLUGGING POWER CORD FOR TEN MINUTES.
  • Ginko
    Ginko Nov 02, 2008
    Oops, sorry for capitals, I had the caps lock on.
    Try first unplugging the power cord for at least ten minutes, if that does not work leave unplugged for two hours.
    This will drain power from TV completely , resetting circuits and solving many problems.
    If that does not work, that means that there is a real fault.
    If it was the protection circuit (all TVs built in the last 20 years have it), then the tv won't even power on. It would stay on standby mode, probably clicking all the time.
    When TV shuts off that way is usually a faulty component that fails when it gets hot, probably a faulty capacitor or IC, that warms up and fails, breaking a circuit or returning a wrong voltage.
    Often you get this because one or more capacitors on the power board had blown.
    The convergence ICs can also fail when TV warms up , but usuallt they do not turn off the TV.
    In rare occasions also a faulty lamp can shut down when it warms up.
    The TV must be taken apart and ispected by a technician.
  • Ginko
    Ginko Nov 02, 2008
    Service manual for this particular model is not available for free download.
    You can try asking a service manual to Philips,calling at 1-888-PHILIPS 7AM-11Pm EST Mondays-Saturdays, and 8AM-11PM on Sundays in US, or calling the customer service for your area listed on the user manual. They will ship the manual (booklet format) for about $30
    If you want instead buy the manual from a private seller, in PDF format, you will pay $9.95, try here (click)
    The wesite says magnavox, but Magnavox 55pp9352 is a retagged Philips.
    If you cannot see the manual in list contact them here (click)
I have the Phillips/Magnavox 3 CD Rotary Changer System and when I try to power down, it shuts off for a few seconds and then goes into Demo mode. How do I power off completely?
without the model number i cant be exact, but if memory serves me you either hold down the demo or display switch for about 5 or 6 seconds
Sep 07, 2010 | Audio Players & Recorders
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
Phillips 47PFL3603d-f7 blinks when turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
May 29, 2009 | Philips 47PFL3603D LCD TV
Wont stay on turns on for a second then i hear a
I have had the same problem with every Phillips with which I have had any experience. Service required, possible DOA.
Apr 17, 2009 | Philips Televison & Video
Phillips 201B4 turns off 2 seconds after power up
first you need to check if your coputer it is powered on. try your monitor to other computer and other monitor to your computer to see where is the problem
Dec 09, 2008 | Philips 201B4099 21 in.CRT Conventional...
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Phillips 36" shuts off
It looks like that your TV is overheating. Most of the TV's have a fail safe so if any case they are over heating it will shut off so it doesn't damage the TV. i would advise that you seek help of a professional in your area.
Jun 17, 2007 | Philips 36RF82S 36" TV
Philips 55PP9352 55" Projection Television Logo
295 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
