Question about Philips Magnavox 51MP392H Rear Projection Television
Blurry.....convergence problem??? l would like to correct my last post..... l get the green bow on the bottom like a 4 inch bow..and then about a 4 inch blue bow......on top of that... l do get a picture but the blues and reds ..and greens dont come toether...l see triple words of red and blue...and yellow/green....l tried to adjust my convergence with the arrow guides and it dont make a differnce...l was told by someone that it could be the convergence board is out...but l dont know....over picture then looks fuzzy and out of focus,,but l can still watch it..just seems out of focus.. like blue, red, and yellow/green coma type images.....anyway is a convergence board easy enough to change myself if that is the problem.... thanks.....
  • brandie_whit Nov 02, 2008
    ... would that be the same solution that l was given before.....
  • fjjj Nov 04, 2008
    I have the 3 color effect going. Don't have the Bowing described in similar threads. I downloaded the svc manual from ServiceManuals.com , as you suggested. I've replaced IC's in school, but we had cut the legs and yanked them out for quicker repair. I was given this TV and the owner told me that they had had the convergence board replaced before, but that could have just been what they told him. I just need to know where the board is (placement wise) and where on the board these 2 IC's are. I am curious about the 120 or 150 variants. I also thought I read a thread describing a 180 variant of the chip.
    Scholar:
  • 33 Answers
I agree with Shuttle83,
except with point #4 and #8,
#4 If you buy OEM Sanyo IC Convergence chips ruff looking black with rounded corners and up them to the next one up they will last longer. if you buy generic shiny smooth black with sharp corners they may only last 5 months. remember you get what you pay for the OEM's are usally $12-15 each, generics are $7-12
#8 you should reset to the factory settings after replacing the Convergence ships before trying to adjust again.
good luck!
Posted on Nov 03, 2008
    Genius:
  • 1,139 Answers
This denotes a convergence problem as you surmised. Believe it or not it would be cheaper for you to replace the two convergence amplifiers and the biasing resistors. You would not actually be replacing the convergence board since these devices are usually located on the deflection board in most cases. However in answer to your question, the boards are easily removed, depending on your level of patience (lots of cables to move around), I would also advise you to either mark down all of the connection you will remove, or take pictures of the board and its connectors. If you choose to just replace the Amplifiers and the biasing resistors there is a lot of information on this site on how to do so: This will get you started:
1) Unplug the TV and then get a schematic of the TV I use http://www.servicemanuals.net or http://www.manualsparadise.com
2) On the schematic locate the STK392-xxx series IC packs (usually attached to a large heat sink)
3) determine if the STK392s are 110, 120 or 150.
4) if the STK392-xxx's are 110s replace with 110s (forget that upgrade stuff it is a hit or miss game that I don't believe you want to get into), if they are 120s replace with 120s and so on.
5)Now to replace the STKs: remove the module from the TV and unsolder theold STKs along with the bias resistors, and replace them with the newones (be sure to apply heat sink paste to the STKs when attaching themto the heatsink)
6) make sure there are no short circuits form your soldering job.
7) Reinstall the module and then turn on the TV.
8) do an auto-convergence test and then things should be back to normal.
Now if you think you can do this have at it, if not I would suggest that you have it done by a qualified TV technician.
Posted on Nov 02, 2008
  • Henry McKelvey
    Henry McKelvey Dec 04, 2008
    Hello flll,
    I can tell you what to look for as far as the convergence ICs. Look a large heat sink, with two STK type Amplifier ICs on it you can not miss it because the look like the ICs you use to find on stereo power amplifiers. Look for two black or blue rectangular (with the corners cut off) looking components with 18 pins each and those are your convergence amplifier ICs. The board to which they are attached with be the deflection board. It is usually located on the right side of the TV looking from the rear.
    I hope this helps,
    Shuttle83
    http://www.electron-age-technologies-llc...
My screen has a slight bow shape
its probably convergence -
here is my tutorial
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
rca hint at the bottom.. it probably needs a convergence power board, easy install.. 4 screws and 2 plugs(wires)
Jun 18, 2010 | RCA P52960 52" Rear Projection Television
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Lines are bowed at top and bottom,picture is blurry
Is the convergence option still listed under the on screen menu setup options, or has it disappeared?
Jan 22, 2010 | RCA R52WH76 Television
3D picture with bowing effects
model number is located on bottom rear cover, your convergence circuit has failed but without model nobody can give you further info, re-post and we`ll try to help, video-tek
May 28, 2009 | Televison & Video
Picture is blurry and is shaped like a bow tie on my tv
This is a convergence problem that you can fix if you can solder. Let me know if you wish to attempt the repair and I'll post additional details and instructions.
Dan
Oct 10, 2008 | Mitsubishi VS-55707 TV
SPEED BUMP OR BOWING
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking. Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com for a kits.  Just make sure you replace both of the convergence chips and all of the convergence resistors.
Aug 25, 2008 | Philips 60PP9202 60" Rear Projection...
Panasonic rear projection tv, there is a bow at the top and bottom of the screen which makes a double image in blue and green.
Please respond to this same post with your model number and I will post the correct IC numbers of the convergence amp ICs which need replacing.
Jul 12, 2008 | Televison & Video
Green bow tie, convergence not helping
Yes, your geometry correction has failed and you will need to seek qualified tech for help. You need what are called STKs and you should be able to get the job done inhome for under 300.00
Craig www.classtorations.com
Jun 08, 2008 | Samsung PCL545R 54" Rear Projection...
Mitsubishi Vs-6047 Convergence Problem...Please Help!
usally convergence green is split between 2 ics. so if your blue and red are still good. it might be the green output resistors. The
Jan 08, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
