Question about Samsung Syncmaster 730B 17" Flat Panel LCD Monitor
Two vertical lines across screen
I dropped my monitor one day.when i turned it on after that i noticed two vertical lines across the screen about an inch thick each.the first one is usually a white colour but would sometimes change to a different colour.the second one is always black.there's no crack on the screen.i've changed vga cable,i've tested cables within the monitor and there are no breaks.i need some help
  • NancyDinCO Aug 09, 2008
    Vertical colored lines ... I now have red, yellow, blue, 2 greens ... no solution available?
  • 130 Answers
The other thing you could try is taking apart the monitor and receding the video on the back of the panel.
Posted on Jun 12, 2009
I have the same thing on mine. It turns out its a sort of burn-in. If you leave a window in the same position all day then change the screen to a blank colour you can see the outlines of the window still on screen for about 8 hours until it fades away.
Posted on Apr 16, 2007
  • 105 Answers
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Posted on Sep 24, 2006
  • mike fischer
    mike fischer Oct 22, 2008
    So you think my advice is inappropriate?
    DON'T DROP YOUR LCD!!!!!!
    Feedback from idiots is worthless!
    Monitor Mike - professional monitor repair.
4 Suggested Answers
MUKHTAR
  • 2022 Answers
SOURCE: samsung 172n monitor
first you try with direclty connect to cpu without any convertor and extension cable and see if it work that mean problem with your convertor or may be the cord. if it not showing any changes show it service personnel. bye
Posted on Sep 25, 2007
Cerfer39
  • 709 Answers
SOURCE: Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Posted on Oct 10, 2007
SOURCE: Syncmaster 245B Monitor Shivering horizontal lines
Dead pixel 100% My first 245BW had a dead pixel, exchanged it. This is why you buy these because of the 3 year factory warranty.
Posted on Oct 26, 2009
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
AOC vertical white line moving across the screen
I have dual AOC i2553ph monitors. One day I came into work and notice one of them had a single vertical white line moving slowly back and forth across the screen that looked like a scan or radar function. I reset the monitor from the OSD and all is well again. Use "Extra > reset" from the OSD on AOC monitors.
Jan 31, 2012 | AOC Computers & Internet
Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Jan 29, 2009 | Dell P1130 21" CRT Monitor
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
A white line across my screen
I got the same problem, I'm going to return it to the store today...
Nov 27, 2007 | ASUS VW192S Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Vertical band on new monitor
Without a second thought, send it back.
When you say the monitor has not be dropped, wht you are really saying is it has not been dropped by you.
There were alot of hands involved in getting it from the production line to your house.
At any stage it could have been dropped or given some form of impact (normally in transit)
That fault is in the panel itself and cannot be fixed.
Nov 06, 2006 | Dell UltraSharp 1907FP 19" LCD Monitor
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Samsung Syncmaster 730B 17" Flat Panel LCD Monitor Logo
1,020 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
