Question about Technics SL-MC7 110-Disc CD Changer
Technic sl-mc7 110-disc cd changer
The disc changer ,u plug it in and it s display reads checking disc.and wont do anything elsce 2.the first time i could use the disc phone pad ,then it read error. 3.i have never used this disc changer so i want to find out if its not functioning right,if i should or if its worth having it look at an by wom should i or do u have some one you could reffer me to thank u
The problem is likely the carriage drive belt. The player is well over 10 years old so the belt gets stretched with use. Then it is unable to transfer power for moving mechanisms.
If you feel comfortable about opening the cover using proper electrical safety procedures then you can observe what the carriage is doing upon turn on. Unplug the player, remove the cover by unscrewing four fasteners (I think, but you can easily figure it out), plug in and power up. The carriage should go through a positioning calibration and disk checking sequence (simply, it moves out of the home position, travels across the player and repositions itself to await front panel input).
Yours probably doesn't so look at the belt on the top of the carriage. If it is off the drive wheels, remove electrical power, then simply put it back on, power up, and recheck.
If the belt is spinning on the wheels and seems loose then it needs replaced. Fortunately, here is an inexpensive and attainable replacement courtesy of another FixYa poster
http://www.fixya.com/support/t1616894-looking_drive_belt
Also, a clean up and lube of the mechanisms would be a good thing to do. That takes some technical know how to clean without damaging and applying the correct lube in the right amounts to the appropriate mechanism components. Some general references are available in electronic service books or online. I should probably launch a site!
Otherwise, without knowing the conditon of other components in the drive assemply, a service manual is required to proceed with further troubleshooting specifically for the player.
Hope that the K.I.S.S. approach helps you enjoy your player again.
Posted on Aug 06, 2009
Problem: The Sl-MC7 C.D. player will only play a C.D. in the single slot, but it would not play a C.D. in slot one to one-hundred and ten. When ever you are tring to play a C.D. in slot one to one-hundredand ten, the machine will try to locate a C.D. but the screen will displays NO Disc. I repair audio and video equipment. Solution: The solution to this problem will need someone who knows how to use a soldering iron, because some soldering is necessary. The machine have a cyristal clear L.E.D. which is located on the top of the transport. The transport is the piece that plays the C.D.,s. The L.E.D. looks like a little flashlight bulb. Below the L.E.D. there is a black part which is mounted on the same P.C. board but it is located at the bottom. The black part is use for receiving the light from the top L.E.D. The machine locates a C.D. by moving the transport with the L.E.D. over the C.D.s in the slot. When the machine perfrom this process, the C.D.,s in the slots blocks the infarad-light which prevents the infarad-light from intering the black part-the receiver which is mounted on the same P.C. board but which is located at the bottom. When the C.D.,s in the slots blocks the infarad light, this blocking of the light sends a signal to the C.D. player computer. This is how the machine knows where to locate a particular C.D. I had this problem with a machine that I had purchased I had to scrape the copper trace at the L.E.D. connecting point and also I had to carry-out this same process where the black part infarad recerving sensor which is located at the bottom of the machine. I also had to carry-out the same process on a P.C.board which is located at the bottom about half inch toward front left from the infarad receiving sensor. MAKE SURE YOU REMOVE ALL ELECTRICAL POWER FROM GOING INTO THE MACHINE.
Posted on Mar 17, 2008
    Novelist:
    Champion:
  • 275 Answers
Buddy, you gotta take it to the Company Service Center.
Posted on Sep 25, 2006
Where do I find the laser on my technics sl-mc6 CD changer Keeps reading checking discs
Place a disk in the machine and as it is reading it, pull the power plug. Then open the unit up and it the laser will be under the disc in the machine.
Dec 27, 2017 | Technics Audio Players & Recorders
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
Troubleshooting cd player
Your Optical Pickup is worn out. When you put the disc in the drawer, it must load to read the TOC(table of contents). If it can't read the TOC, it will stop or eject.
Aug 17, 2014 | Technics SL-MC3 61-Disc CD Changer
Hi i have technics Compact 5 Disc Cd Changer SL-EH790
Carousel-type changers such as yours are prone to eventual failure.
Mar 23, 2014 | Technics Audio Players & Recorders
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
My Technics SL-PD987 5-Disc, does not read CD any more. First did not read burned CD, after did not read original CD.
Power the unit off. Unplug it. Press the power button for 30 seconds. Plug it back in and try again.
If this doesn't resolve the problem, I recommend a CD cleaner. This is a CD that has a small brush attached. It will clean the dust from the laser reader.
If this doesn't work, I'd suggest a professional repair shop.
Apr 15, 2011 | Technics SL-PD987 5-Disc CD Changer
SL PD887 5 disc CD changer was working one day but not the next day - does not read the CD - goes from one CD to the next but unable to read each CD in the changer. Have changed the CD's and cleaned the...
I have a model sl-pd847 and experience similar problems to many other submitters. I checked the main pcb and found discolouration around what appear to be 2 (power?) transistors and probably a voltage regulator. After about 4-5 minutes after switch on these get really hot. I suspect that may be the reason why it doesn't work anymore. Worth fixing? I don't think so. This one didn't even play CD-R let alone CD-RW! Get something a bit more up to date I say.
Jan 16, 2011 | Technics SL-PD887 5-Disc CD Changer
Technics 60 cd changer cannot see disk in changer
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the CD Changer not reading discs is a bad drive. The following website sells the drives and does installs:
http://store.richspsxparts.com/wiiredvddr.html
This drive should fix any reading issues you are having with your disc, or issues inserting your disc or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your CD Changer.
Hope this will help...
May 26, 2010 | Technics SL-MC70 60-Disc CD Changer
I have a technics sl-pd887 5disk changer that
I contacted a friend who operates a sterio shop and was convinced that fifteen years of bouncing up and down has made the laser unable to focus and read the info on the disks and the solution is to buy another one . Thanks for you're interest.
Nov 20, 2009 | Technics SL-PD887 5-Disc CD Changer
Technics SL-MC7 110-Disc CD Changer Logo
847 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
