Question about Air Tools & Compressors
BNA125A Porter and Cable brad nailer
When I pull the trigger it will punch the nail in but the hammer stays will not retract until I remove the air from the nailer.
  • Snydermann Nov 24, 2008
    I have a very similar problem with a DA250B finish nailer. The driver won't retract until you fire the gun a second time.
  • Anonymous Mar 15, 2014
    How to load porter cable finishing nailer
    President:
  • 1,388 Answers
Both of these nailers have a check seal about half way down on the cylinder. This check seal causes the piston to retract if the piston ring is not too worn. The lower bumper should not be cracked and missing pieces, and the driver guide washer must be in place below the bumper. Also check that the driver is not bent causing it to get stuck. The da250b has an upper bumper of sorts and developes cracks that can only be seen by removing and inspecting, If cracked, the upper bumper must be replaced for proper function. The bn125a nailer probably has the discharge port clogged or upper valve parts worn or cracked. The headvalve should be inspected for cracks where the oring fits and the rubber seal should fit snug on the valve. There is a spring that pushes down in the headvalve that pushes from a rubber washer of sorts, check the diagram to be shure that all parts are in order. Both of these guns will not take too much pressure. Try adjusting to about 90 lbs max.
Posted on Nov 25, 2008
How do I replace the trigger valve assembly on a Porter Cable DA250C nail gun
There is one pin with a retaining o-ring that must be removed holding the trigger arm in - then there are 2 roll pins that must be driven out with a small punch that hold the trigger valve. Once the 2 pins are removed the trigger valve can be pulled straight out.
When you install the new trigger make sure the recesses in the trigger line up with the holes for the retaining pins.
Porter Cable DA250C Type 1 15 Ga 2 1 2 34 Angle Finish Nailer Parts
Feb 12, 2015 | Porter Cable Air Tools & Compressors
Hi I am having problems with my porter cable air nailer.. 2" brad nailer.. The hammer is not retracting far enough to hit the next nail.. I have taken it all apart and cleaned it and re oiled it but...
This is usually a sign that the hammer is slightly bent or the o-ring seal is going bad. You have to replace the hammer. If replacing the hammer doesn't work, the barrel it rides in is out of round and will need replaced. These pull out hard and you need allot of grease and patience to get them back in square to keep the seals intact.
Mar 03, 2011 | Porter Cable PorterCable FNBNNS3TB Factory...
Porter Cable FN250 will not advance the nails to the hammer. It appears to be an alignment problem. The nails stop on side of the hammer and not under it. It looks like the nails should be held "tighter"...
UNPLUG nailer. remove all the nails and look for a jammed nail in the magazine/ose area. Next check to make sure using the right guage nails for this tool and then look for a bent or broken driver blade. all the above could be causing you problems.
Sep 23, 2010 | Porter Cable 1" 18 Gauge Brad Nails...
Hello My PC 18ga brad nailer its piston wont retr...
Check the regulator gauge on your air compressor to make sure you have enough air pressure going to your nailer. After replacing my nailer because the driver wouldn't retract, I discovered, when the replacement nailer had the same problem, that I had somehow turned the regulator and decreased the pressure. Now I have two fully operational nailers.
May 20, 2010 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
I have a poter cable brad nailer and after running
Sounds like a trigger seal. I assume this is an oil-less brad nailer as that is the standard. You should be able to find the seals at any local hardware store including Home Depot or Lowes. If you can't find the portercable O-rings just grab the random assortment from Bostitch which is usually readily available. Refer to your parts manual for the correct size/gauge
Apr 15, 2010 | Porter Cable Cable Brad Nailer and...
I have a FC350A FRAMING NAILER, IT IS IN THE
check to make sure that there is not a nail jam , if the driver will not retract then the gun will not cycle . if no nail jam then replace the inner trigger
Feb 02, 2010 | Air Tools & Compressors
Porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Aug 29, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
The hammer will not return to neutral after firing. Porter Cable with little use but purchased several years ago.
I removed the head of the nailer and then pulled the hammer out of the cylinder. I removed the o ring and carefully cleaned each part of all particles and blew the cylinder out with an air hose. I placed a couple drops of the proper oil on the slot for the o ring and a couple drops in the cylinder and reinstalled the piston/hammer being sure to match the hammer grooves into the guide/nail slide. I replaced the large o ring in the head mechanism after carefully cleaning and oiling as above. After reassembling, the nailer worked like new.
Aug 04, 2009 | Porter Cable 1" 18 Gauge Brad Nails...
Brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Apr 27, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Nails not feeding in
The unit need cleaning and oil. Possible a wix spring.
Mar 14, 2009 | Porter Cable-Cable BN200B 5/8-inch to...
Air Tools & Compressors Logo
217 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
