Question about Optics
Fuzzy bright stars with my Celestron CPC 1100 XLT
When looking at the brighter stars I cannot focus them to a sharp image. They appear fuzzy. Image of a star test on Vega attached (taken with a Watec 120N webcam). Diffraction rings are sparse and mottled. Does not really indicate that scope needs collimation. Can you help please.?
Thankyou
Mike Brightmore
michael.brightmore@ntlworld.com
  • Anonymous Dec 20, 2008
    All objects seem out of focus no matter how I adjust the focus knob.
    The images of stars look similar to your picturs. The moon's craters can be seen, but they do not have the sharp definition I was used to with other telescopes I have used. I was told that this could be an issue of the telescope needing to be collimated (sp?) correctly. I noticed that the stars are slightly tear drop shaped which leads me to believe that the optics are misaligned. How is this done? I had a reflector and the process was easy. How is it done on a Celestron Schmidt-Cassegrain?
    Genius:
  • 1,027 Answers
The image shows that the optics are not centered properly. The secondary may be tilted slightly to the 2 o'clock position. When not centered, a focused star will have an astigmatic shape, and not come to a full focus. Also check the mirror and corrector plate for dewing, that will also affect the views.
Posted on Nov 08, 2008
I have had the same problem, but when I got used to the collimation process and which way to turn the adjuster screws life has been much easier for photographing, usung a 7.5mm eye piece for adjusting the perfice circle.
Posted on Aug 20, 2010
When using telescope for the first time (looking at venus) it would not focus, also the cross at the front of the tube was most prominent.
Do stars appear as small pinpoints in your scope? If not then it sounds like you have not adjusted the focus properly. I recommend you take your telescope outside in the daytime and point it toward a building or tree or hilltop that is somewhat distant from you. The exact distance is not important, but it should a block or more.
With the telescope pointed at the distant object, focus the telescope until the object is sharp and clear. The object might appear upside down -- that's normal for many astronomical telescopes. When you have achieved a sharp focus, leave the focus control alone until you are outside at night under the stars.
The focus should now be fairly close for viewing stars and planets. Small adjustments of the focus control may still be necessary for the sharpest view.
Venus is sometimes a difficult object. It is often fairly low in the sky where the atmosphere is most likely to blur the view. Find a bright star and focus it to a pinpoint, then swing your scope toward Venus.
- Jeff
Dec 27, 2016 | Celestron Optics
I have a Celestron C-90. When I turn the focus barre; it goes through focus but never getgs a sharp inage
Your friend may have dropped it, causing it to go out of collimation (optical alignment).
To test this, set it up outside and allow it about an hour to cool to the surrounding temperature. Then point it at a star of low to moderate brightness, and defocus slightly. You should see something like one of these images
http://legault.perso.sfr.fr/airy_collim_2.gif
If the rings are not concentric, shown in the bottom row, the scope needs collimation. These scopes were not meant to be collimated by the user, being glued together, so you will probably have to send it to Meade.
If concentric, as in the top row, it is OK. In that case, seeing conditions were just not good, or your lenses need a clean, or there was dew on them.
Apr 03, 2012 | Optics
Am I supposed to see the cross in the centre of image on celestron 76eq
You will see diffrection spikes when focused on a very bright object
http://www.goldastro.com/images/newtonian.jpg
and this can also appear around a bright planet. However it is very irritating, and to minimise it, make sure your scope is well collimated (optically aligned).
There is too much to collimation to include here, but there are many guides on the Net
http://www.cloudynights.com/documents/primer.pdf
http://www.atmsite.org/contrib/Carlin/collimation/
Feb 22, 2012 | Celestron FirstScope 76EQ (180 x 76mm)...
Is there a fuse inside a CPC1100?
Yes and several circuit boards-- usually but not always-- any electrical issues are on the BOARDS and not the fuse.
Time to return it to Celestron- call them for tech advice here--
http://www.celestron.com/c3/page.php?PageID=37
Jul 29, 2011 | Celestron CPC 1100 GPS (XLT) (70 x 280mm)...
Need to replace GPS module on celestron CPC 1100 xlt. Where can I find this part? Thanks
Contact Celestron at this web site-- best to call them--
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Jul 29, 2011 | Celestron CPC 1100 with Standard Coatings...
My webcam is coming up very blue and fuzzy is there a way to fix that for the Toshiba satellite L655
Hello!
Webcams in general have very low resolution. But you can improve the appearance of your image with this little trick:
Before the webcam starts capturing, try pointing it to a light source, so when it starts it should receive enough light to provide a brighter image afterwards. You can take it off the light source when you see that the image improves and use it normally.
This happens because most webcams' drivers are programmed to display an image based on the initial light conditions. So if you start using it in a dark place, when you try to move to a brighter area, the image would look blue and fuzzy, as the webcam was adapted to those lightning conditions.
Hope this helps.
Good Luck!
May 04, 2011 | Computers & Internet
I have a new Celestron 114M Newtonian telescope that when trying to look at Jupiter all I see is a smear of light and when I focus in I see the black cross bows of my telescope on top of a bright white...
USE only the eyepieces do not use the 2x barlow. Try again with just the eyepieces starting with the one with the largest number written on it. Focus slowly until you get a sharp image-- you can practice during the day time on a distant object.
Read my tips on my profile page.
Jan 10, 2011 | Celestron Optics
Obscured view through telescope
You can slow down dew forming on the mirror by NOT pointing the telescope toward the sky during cool-down-- just leave it parallel to the ground. Same goes for your eyepieces -- leave them covered, or inside a case.
Dec 26, 2008 | Celestron AstroMaster 130EQ Telescope
Optics Logo
978 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
