Question about Frigidaire FRS26RLECS Side by Side Refrigerator
Freezer losing temp... intermittent buzzing sound
My Frigidaire FRS26RLECS is having some problems keeping the freezer side cold. Ice is starting to melt. Probably going to lose the food. It's still running, and every few minutes there is a buzzing sound. Fridge side seems okay for now. I turned the temp gauge colder, hope it'll keep the food okay til tomorrow morning (nobody seems to be open Sunday). Fridge serial is LA40315755 (1/2004 production date).
Thanks for any help.
  • aburki Nov 02, 2008
    Edit: Actually, it seems the fridge is warming slowly too...
    Thank you Techsim. Strangely enough, I kicked the temps a little colder, it seemed to kick something on, because now everything is cooling back down, and the buzzing fan/buzzing noise has stopped. Sounds like it normally did.
    I'll probably have someone come out and take a look anyway. Appreciate the help.
    ab
  • 59 Answers
Either the start device for the compressor is bad or the compressor has died. The easiest way to tell is to replace the start device. It cost around 30-40 bucks and the part number for it is 218721119. In most of these cases its just a bad start device. The start device is located on the side of the compressor in the bottom back of the unit. It will have a capacitor attached to it that you will want to keep and stick on the new one. If you need anymore help just let me know. Good Luck!
Posted on Nov 02, 2008
Have a frigidaire side by side frig temp is fine but freezer is cold but not freezing and auto ice maker won't make ice
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 06, 2011 | Refrigerators
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Freezer not keeping ice cream cold
One thing you can do is clean out the area under the ice box where the condenser coils are located. Make sure the fan motor is blowing under there. Clean the kickplate. Get the air restrictions out of the fins and that may bring the freezer temp back up to par.
Nov 23, 2008 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire does not work (freezer and cool area)
what can u hear. u should hear fan in freezer. fan in back. is compressor running. is ice in freezer on back wall. are both sides not cooling. post more info to go by
Jul 02, 2008 | Frigidaire FRS26RLECS Side by Side...
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Frigidaire FRS26RLECS Side by Side Refrigerator Logo
399 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
