HARD Disk I have a computer P4 with XP, some days ago i have just installed a new hard disk so now i have 2 hard disks, since now every thing was correctly, for the first time i insert a new UPS and at moment in time i was getting MSG no signal or cable disconnected, when i went to the bios i found that the hard disk was not didected the 2 HD the new & old HD, can some give help thanks.
    Genius:
  • 1,250 Answers
CHECK THE CABLE AND POWER CONNECTOR OF BOTH harddisk , also check their Jumper setting if you have attach through a single cable.
Posted on Nov 03, 2008
DELL Inspiron disk failure how to recover OS in new hard disk?
Unfortunately you will need the restore disk to correct this problem. Even if you copy the old disk to the new, chances are you will copy the corrupt files and have TWO bad copies of xp. You can order the restore disk from Dell on average about $30.
Good Luck
C2Solutions
Jan 28, 2010 | Dell Inspiron 6000 Notebook
No operating system found
just try to repair your OS if you are using windows xp. use that repair option after F8 during installation of XP.
Jan 07, 2010 | Compaq Presario Notebook
Installallation of xp
the xp does not recognize the SATA hard disk of your computer, you must install SATA drivers during the installtion of XP.
Sep 16, 2009 | Microsoft Windows XP Professional With...
My system is not stable
Can be virus...hardware..or o/s issue
  1. Try taking unwanted files or prrgrams
  2. empty the temp folder
  3. Scan using latest anti virus
  4. Defragment
  5. if still same. Try formatting and re-installing the o/s..
  6. if still the same check replacing HDD ...or M/B
May 22, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
How do i install seagate st3500320as 500 gb sata internal hard disk on a msi 845pe max2 series motherboard. i have installed the hard disk, but it is not detected. presently i have a 40 gb ide hard disk...
ther are jumpers betwwin the data cable and power cable of hard disk...ur 40gb hard disk will be on primary...if u are attaching ur hard on same cable u should put jumper on Secondry
Mar 10, 2009 | MSI : 845PE Max2-FISR...
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Samsung Hard Disk MP0804H
maybe your HDD are not compatible in your laptop. try to look it in your manual if it is compatible or not.
Jan 29, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Service pack3 crashed puter - after reinstall machine thinks extra hard drive is a disk drive.
You can get to the BIOS by hitting DEL or F2 at start up.
However, that does not have anything to do with a drive letter.
Drive letter designation is set in
START>SETTINGS>CONTROL PANEL>ADMINISTRATIVE TOOLS>COMPUTER MANAGEMENT>DISK MANAGEMENT.
Hope this helps.
Sep 06, 2008 | E-Machines eMachines Desktop PC
2 hard disks
Because you have a dual boot system, you have two 'C' drives, which in fact is a good idea if you get a system failure on the drive you are using, you can select the other and still view any files on the other drive through my computer.
f using XP, right click my computer, then properties, then click advanced tab, then startup and recovery listing click settings, at the top system startup, select the default operating system, then click EDIT button, then delete the value that points to the other hard drive more than likely listed as disc1, disk 0 will be the one you have connected as master boot hard drive
Aug 29, 2008 | Microsoft Windows XP Professional With...
Istalling windows
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
