Question about GE DPSR483EA Electric Dryer
My dryer is blowing cold air.
We tried flipping circuit breaker off then on but didn't help. About 2 months ago we cleaned all lint. We do have a DPSR483EA dryer
  • ritann Nov 02, 2008
    Thanks! My husband and brother took it apart and found the broken element.
  • ritann Nov 04, 2008
    soorrrrry!!! it's the first time I've ever been on here!!!
    Genius:
  • 1,122 Answers
Well if it was the door switch or heater box fuse nothing would work,i'am almost sure it's the heating coil that's broke,it is a $39 part online ,it's pretty easy to do,let me know if if you want to give it a shot,before ordering we'll check to make sure that's it-mike
Posted on Nov 02, 2008
  • MIKE major Nov 03, 2008
    i give you the right fixya answer and you gave me a helpful rating,what's up with that ,you messed up my expert rating,,can you please change your rating to a fixya?mike
    please change your rating to a fixya rating as i have given you the correct fix,and you damaged my expert rating-mike
My dryer we've had for about two months won't dry clothes. it heats up, but they are still wet four cycles later
I was thinking you have a bad circuit breaker. This dryer runs on a 2 pole 30 amp 240 volt breaker. The motor runs on one side of the breaker on 120vac. The heater has to have 240 volts to work correct. When that breaker is on the way out it will take a new dryer 3 or four times as long to dry the clothes. themobilian_294.jpg
If you are cleaning the lint filter out and don't have a clogged vent pipe themobilian_295.jpgthen in my opinion you have a bad circuit breaker. Seen it.
Nov 27, 2010 | Amana NDE2335AY Electric Dryer
Our Neptune only blows super hot air. Which may sound good but it is ruining the clothes. It will not blow cooler air at all. Seems like this problem started more than a month ago. Is there an easy fix...
Clean the lint out of all air passages including the exhaust hose to the outside. Wash the lint filter in hot water and detergent to clean away fabric softener deposits which block air flow. Make sure that nothing is obstructing the air intake for the machine. If the problem continues, the heater thermostat may need to be replaced. Hope this helps!
Jul 18, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag front load dryer turns on and runs,it does not blow any hot air
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer gets really hot, blows circuit breaker, vent is clean and clear, circuit breaker replaced, seems to be something that controls the heat isnt working..
Howdy: In back of the dryer is a thermostat (inside) that lint hangs to. If it reads too hot it should stop heating. If not working then blows breaker. Inspect please, we do not want a electric fire. Good luck - Doug
Dec 09, 2009 | Kenmore Dryers
LG Dyer blows 30amp fuse frequently
Hello davidkado,
There is a high probability that when you replaced your fuse box to circuit breakers that the wiring at the fuse box was retightened. If your dryer had been operating Ok for the better part of a year and then you started to blow fuses on a regular basis.. chances are the wiring coming from the fuse box tap was becoming loose from thermal expansion and contraction and that by changing to a breaker system.. your wiring was cut and reterminated to fit the breaker tap. I suspect you won't be having any additional problems...
Regards,
Rick
Jan 02, 2009 | LG DLE2514 Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Code "PF" = N/A
Soft Touch -PF- means power failure, nothing else. Most likely the problem is not with the dryer. The circuit breaker became too weak for the dryer load. I beleive replacing the circuit breaker will solve the problem. Gendos...post back
Feb 25, 2007 | Whirlpool GEW9250 Electric Dryer
GE DPSR483EA Electric Dryer Logo
91 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
