Question about Riso RZ220 Duplicator
Help me quickly
Error Code (E 220} IR 5000
please help me to solve this problem
  • 318 Answers
Scanner home position sensor,faulty scanner error .Switch machine on/off if the error still show you will need a qualified tech to atted to your machine.
Posted on Nov 03, 2008
- Burned(blown) out fuse FU1.
- Lamp of expo defective LA1.
- Cut stragger.
- Card(map) of regulation of defective lamp.
- Card(map) of defective command(order).
Posted on Dec 06, 2008
Canon ir 2230 giving me an error E000024-0001 how to solve this porblem
That code means problem with toner sensor in developing assembly, try cleaning it out the best way u can, if that does not help you will probably need to replace toner sensor itself. (Toner Sensor FK2-0358)
Dec 22, 2016 | Canon IR 2230 COPIER FOR 220 VOLTS ONLY
ERROR CODE IN IR 7095 EOOO2- 0001
this error refer there is a problem in the fixing unit, check thermistor and clear that error from service mode
Apr 13, 2014 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
My copier is apear code E00014
your machine canon iR5000P your Error E00014 i not solve
Aug 21, 2012 | Canon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
My iR 5000 had an error code E000004-0000. solve this
Contact a Canon Dealer/Authorized Service. It's either an error that needs to be reset or you have a hardware issue... with some errors, once you get it, it will never go away until you get a technician to clear it out.
Nov 25, 2009 | Canon Office Equipment & Supplies
Hello can you really help me solve the error code that i getting on my IR 5000 the code is E000012-0000
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
Dec 25, 2008 | Canon imageRUNNER 5000 Copier
Ir 220
E010 codes relate to the main motor or 24v supply through the interlock system. Check for binding in the main drive, or loss of drive voltage.
Aug 26, 2008 | Office Equipment & Supplies
133 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
