Question about Kodak EASYSHARE 5100 All-In-One Printer
LINES ON PHOTOS
WHEN I PRINT PHOTOS THERE IS LINES THROUGH ALL MY PHOTOS I HAVE BRAND NEW INK CARTRIDGES AND HAVE RECALIBRATED THE PRINTER, THE COLOR IS BAD TO THIS IS THE FIRST TIME I HAVE HAD ANY PROBLEMS WITH THIS PRINTER I HAVE PRINTED MANY PHOTOS ON IT ANY SUGGESTIONS?
    Genius:
  • 1,250 Answers
Check there must be head cleaning utility for you printer use it then check
Posted on Nov 02, 2008
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Photos print too redish; blues are purplish
Photo Prints Slowly on HP Advanced Photo Paper
... 8250, 8250xi and 8250v Printers - Photo Prints Slowly on HP Advanced ... Prints Slowly on HP Advanced Photo Paper - c00564372 ... 8250, 8250xi, and 8250v printers print a photo on HP Advanced Photo Paper slower than expected. The ... s.gif » Choose the Best Ink Cartridges for Your Printing Task
Choose the optimum combination of ink cartridges to enhance photo quality. s.gif » Printing Photos from a Memory Card
... to view, select, enhance, and print photos. You can also print camera-selected photos, photos you ... in the Main tray or Photo tray. Check the Photo tray light to verify that ... Load photo paper. Check the Photo tray light to verify that ... s.gif » Problems Printing from the Photo Tray
Instructions and troubleshooting on photo tray printing issues.
Aug 27, 2008 | HP Photosmart 8250 InkJet Printer
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
Poor photo printing quality with new color cartridge
Shaking these cartridges does nothing except give you a little exercise. If this is a brand new HP cartridge you are having problems with I would return it to the store you purchased it from. HP brand cartridges should not give you these problems right out of the box. The print defects you are seeing are due to a dried up or clogged print head. If you like you can try hydrating the print head on a water soaked paper towel until the ink starts flowing, but there's a risk you will cross contaminate the colors.
Oct 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Epson 1400 Printing Orange colors Green
The problem can be two fold. Wrong cartridges, or blocked/damaged inkjet openings. Return it to the seller under warranty if its brand new. If it was fitted with non epson cartridges your warranty may be in question.
But I could almost guarantee the black qand the blue cartridges are faulty or their feed jets are
Jun 20, 2009 | Epson Stylus 1400 InkJet Photo Printer
My canon pixma 4000 lide won't print yellow, even with a new tank
I doubt your printer needs recalibrated. If one color is not printing, check the following :
1. Is the suspect ink tank snapped firmly into place?
2. Did you remove the sealing paper pull tab completely off of the tiny air hole on the cartridge? I've had this happen and found the paper or a small part of it to be still in place which prevented the cartridge from working.
3. Try using the maintenance tab on "control panel" "Printers" "properties" and do a cleaning of the print nozzles. Do a "Print test pattern" procedure to see how your progress is working out.
4. If all fails, try another yellow cartridge. It may be defective
Mar 18, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Kodak EasyShare 5100 won't print
I have had the same frustrating problem.
I cntacted the Kodak live web chat help line and after removing the print head,switching the machine off for 1 min and reconnecting.Clean heads and recalibrate.
.....Still the same.
They then told me the print head was faulty and to contact Kodak for free repalcement.
Sep 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Ink cartridges
The symtoms of a dried out cartridge is white lines through the printed letters.
I've seen brand new dried out cartridges.
Aug 08, 2008 | HP DeskJet 882c InkJet Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
51 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
