Question about Dryers
Whirlpool Duet Steam Dryer Beeps 3 Times But Does Not Start
Our new Whirlpool Duet Steam Dryer beeps 3 times but does not start when we press the start button. This is an electric dryer - not one operating on natural gas. Home Depot tested the two bullet-type 30-amp fuses and said that they are good. Is it possible that one of these fuses is not good and when this is true all the lights on the panel still work? Also, is there a 15-amp time-delay fuse which we need for this dryer? I cannot locate any 15-amp circuit with a time-delay fuse in it assigned to the dryer on my electrical panel.
Please reply as soon as possible. My wife and I spent close to $4,500 for our new Whirlpool Steam Duet washer, dryer, 15.5 inch pedestals, 5-year extended warranty & all taxes in Canada and my wife is freaking out because our new dryer is not working.
  • 3 more comments
  • Anonymous Mar 14, 2009
    Exact same problem as the poster. Only difference is that we have a gas unit.
  • Anonymous Mar 19, 2009
    exact same problem with my new electric unit
  • fish-boy Apr 13, 2009
    Same problem. Tried starting it at least 50 times on the same load. It seems to be the latch. Try slamming the door hard. It worked, but you really shouldn't have to slam a dryer door to get it to work.
  • Anonymous Apr 30, 2009
    exact same problem
  • olivia1682 May 20, 2009
    Same problem here. Slamming door worked. Pretty effing ridiculous if you ask me.
Brand new unit - same problem. After an hour of investigating, I found the issue.
You don't actually have to SLAM the door. If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Yay!
Posted on Oct 13, 2009
  • awsomex Oct 17, 2010
    This was the problem. My son pulled down on the door and must have bent it enough not to make contact with the latches you mentioned. Lifting and closing the door solved the problem for us. Thanks for the research...
MisterMighty's tricked worked perfectly on my new Kenmore he5T dryer...it is pretty ridiculous though! Thank you MisterMighty!
Posted on Oct 28, 2009
Unreal,did not start, ran upstairs, slammed door real hard, it stared, thanks
Posted on Feb 22, 2011
Thank you so much for that info! I was so nervous. Now I'm a happy camper :-)
Posted on Dec 11, 2012
Dryer won't start, push the start button it just beeps
It is possible you have a broken drum belt. You may need to call a qualified service man as changing a belt can be tricky.
Oct 01, 2015 | Whirlpool Duet WED9550WW 27" Electric...
Error code of three beeps on a whirlpool dryer model 68972981
Hi troy crawford,
Well if it beeps for 3 times and then shut off when you press start it means that the dryer thinks that dryer door is open. You will have to replace your door switch to fix the problem. or you can also try closing the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. many time it will works...
Good Luck
Regards
Nov 07, 2011 | Whirlpool Dryers
Duet dryer beeps 3 times when start is pushed and it doesn't start
I have the same exact problem. Just happened today. I think it is the thermal fuse. I now need to buy one and see if it really solves it. Good luck
Nov 08, 2010 | Whirlpool GEW9250 Electric Dryer
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet gas dryer. was working fine now all light and time amount work but will not start and beeps 3 times
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool duet dryer will not start. Power
You have to slam the dryer door shut. Sounds silly... but it worked. Guy said it has to do with it being stacked??
Jan 11, 2010 | Whirlpool GEW9250 Electric Dryer
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
3,884 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
